- Joined Jan 23, 2018
- 28,276
Probably the original application was in an automotive alternator embedded into a massive heat sink and with perhaps 50 CFM of airflow constantly.
Could be. I've not compared spec sheets from several different mfgrs. for this part number. There are even Schottky versions, which seems weird -- I thought the "10" in the part number referenced the 1000v Piv, and that Schottky "20A10" I saw a datasheet for yesterday had a PIV of (somewhat expected for its type) 70v.Probably the original application was in an automotive alternator embedded into a massive heat sink and with perhaps 50 CFM of airflow constantly.
Yeah, that's the fallback plan. I also have a 200 amp diode out in the shop somewhere. Not sure of the voltage rating but IIRC it came out of a 480v 3-phase device. It'd be it's own heatsink, but it's not gonna fit in a "handi-box"!Yeah, you might want to think about devices that are capable and built to be designed for heat-sink mounting, such as the alternator variety mentioned.
e.g. pressed-in versions.
I doubt very much that the manufacturers ever use a diode in a space heater.would a Schottky diode dissipate less heat? What do space heater MFG's use?
I just looked inside one, and the low/high switch is either direct or through a shrink wrapped bulge (diode)? on half power. Next time I take it apart I guess I will test if it's a diode. Not sure what else it could be?I doubt very much that the manufacturers ever use a diode in a space heater.
| Thread starter | Similar threads | Forum | Replies | Date |
| E | Heat sink calculation | Power Electronics | 4 | |
| E | Attaching heat sink on vertical mounted board | Power Electronics | 15 | |
Heat sink thermal paste/glue | General Electronics Chat | 3 | |
| C | Heat sink questions | Power Electronics | 8 | |
The best heat sink design tool. | General Electronics Chat | 6 |
