Heat sink questions
C78
Joined Mar 24, 2025
I've designed a power supply for two LM317 voltage regulators and specified a heat sink using very conservative values to avoid any issues -
The regulators share the heat sink so I've summed their power dissipations together
PD 1 = (26V-17V) * 0.4A = 3.6W
PD 2 = (17V-12V) * 0.1A = 0.5W
PD total = 4.1W
Rjc = 5°C
Rcs = 1°C
Max operating temp = 100°C
Ambient temp = 50°C (room temp is actually 21°C )
Required thermal resistance = 6.195°C
I chose the following heatsink rated at 2.5°C/W
https://uk.rs-online.com/web/p/heatsinks/7226928
I thought this should be more than enough, but the surface temperature of the heatsink is 51°C after being on for 30 minutes. This seems hot to me, given the size of the heat sink.
My questions are -
Am I right to just sum the power dissipation of the two regulators together and then calculate the heat sink required for them to share?
Is there a way to calculate the ball park expected surface temperature of the heatsink?
Likewise, knowing the surface temperature of the heatsink, can I calculate the actual junction temperature?
Thanks in advance
38,943
The given heatsink thermal resistance is likely for it being mounted in open air with the fins vertical.
Is that its orientation?
Yes.
Yes, just use the terminal resistance of the heatsink times the total power being dissipated, and add that to the ambient air temperature near the heatsink.
Yes, you just add in the device junction-to-case, and the case-to-heatsink thermal resistances (are they mounted using thermal grease to reduce the case-to-heatsink resistance?) and multiply that by the individual device power being dissipated.
The heat sink temperature looks about normal for something with no forced air flow to remove heat faster from it. The 'resistance' from the heat sink surface to air needs to in decreased (by being in contact with something cooler) if you want the the thermal chain from device to air to be better than heated air rising flow from the surface of the sink.
C78
Joined Mar 24, 2025
These look great, thank you very much
Yes, it's mounted with the fins vertical
Excellent, thank you. So in theory the heat sink should be between 30°C/40°C depending on the actual air temp around the heatsink
Sorry, I may be misunderstanding, but would this not give me the temperature of the junction if the heatsink surface temp was that of the one calculated, not measured?
Thanks for your help
38,943
Perhaps I wasn't clear.
You add the temperature increase due to the case-to-junction, and case-to-heatsink thermal resistances to the measured heatsink temperature for each device.
C78
Joined Mar 24, 2025
Ah I see, so for regulator 1 -
((5°C + 1°C) * 3.6W) + Measured heatsink 51°C = 72.6°C ?
