H-bridge using IR2184 chip. ..#2
eliegeob
Joined Oct 6, 2025
27
Here is a simulation using LTspice 24.1.10.
I've reworked your schematic. The load inductor vs resistance values didn't seem correct, so I changed the Inductor to a resistive load for demonstration purposes. Simulation completes within 17 seconds.
View attachment 357104View attachment 357103
Hi EE,
i am not quite sure i understand correctly, are you saying that this circuit should work fine if i connect both IN of the IR2194s to the same pulse?
E
eetech00
Joined Jun 8, 2013
4,724
Here is a version that uses the IR21844.
I have the DT pin grounded. It provides a default DT of 400nS. The DT can be programmed by connecting a resistor between the DT pin and ground. There is a chart on the datasheet that shows DT vs resistor values. Note the master clock is 80khz since the FF divides by 2.
