H- bridge to generate cranking in motor with other circuitry
Status
Not open for further replies.
Bhargav Jani
Joined May 20, 2016
114
I am working on a project in which ,
I have to build up a circuit (H-Bridge),with ECU as motor which draws(12V, 10Amps). Analog input to the H bridge done by Myrio (from NI) also to control and alternate switching of H bridge.Motor Cranking is main idea behind making this circuit. The circuit must be able to produce cranking pulse at start up A circuit with few passive components is what i am working on.
2 N-channel MOSFETS and
2-P channel MOSFETS. What other transistor do i need ?
Or a H bridge Driver IC.
The ECU (for eg) which is in place of motor draws some current (10Amps)
Everytime at start-up it is important to have this cranking pulses (test circuit to be made)
ECU - Engine C
ontrol Unit?
OR would be AND. The p-channel mosfets have to be driven by a higher voltage and the driver provides a bootstrap mechanism to do that. Follow the recommendations of the driver whether series gate resistors are required.
You may need logic FETS which means a Vgs below 5V is enough to turn the mosfets fully on.
You may need resistors to drain the gate charge off so they switch faster.
Some H-bridge controls allow fwd, rev, brake and coast; most allow fwd, rev and coast.
You may need a way to monitor current.
Some H-bridge driers need two sense resistors to monitor both legs and to prevent cross-conduction.
"cranking" in a car also implies that there may be a lower voltage of operation required. e.g 8 V or so, not 12 or 13.8.
Not sure what your asking.
Bhargav Jani
Joined May 20, 2016
114
I took a oscilloscope to a tractor yesterday and as I turned ON the starter I could see sudden drop in voltages upto 6-7V and so on within 200ms.
This behavior was recorded accordingly in the oscilloscope. The H bridge in the above schematic with Myrio (From NI) ,together have to attain this scenario of cranking once the FET\MOSFET has inputs from Myrio
Similarlly I have to make a LabView code and also GUI for the same..
But at first what components and the circuit design in eagle is important for me. I need to simulate the circuit before proceeding for PCB.
The aim is to have this cranking motor or such output waveforms at the Myrio GUI , to see the behavior of this Circuit.
I hope i made it clear, I am not sure. I feel firstly the design of circuit is crucial
Bhargav Jani
Joined May 20, 2016
114
Ya
ECU will be tested later for the cranking scenario, At first need to check with load of upto 5amps and 12V at load resistor (in place of a ecu first) .
Status
