Industrial PCIe Gen3 (NVMe) to USB 3.2 Bridge – Part or Architecture Recommendation
Trumpeldor
Joined Jun 24, 2025
Hi everyone,
I am looking for a hardware solution to bridge PCIe Gen3 (NVMe SSD) to a USB 3.2 Host, strictly requiring Industrial Temperature range (-40°C to +85°C).
The Constraints:
1. Physical Interface: PCIe Gen3 (x2 or x4) to USB 3.2 Gen1/Gen2.
2. Operating Temp: -40°C to +85°C (Non-negotiable).
3. Common parts checked: JMS583, ASM2362, and RTL9210. These are widely recommended by AI tools but are Commercial-grade only and don't fit the thermal requirements.
My Questions:
*Dedicated Bridge: Is there an industrial-grade, single-chip bridge IC for PCIe-to-USB (Mass Storage Class / UAS)?
*Alternative Architecture: If no single-chip bridge exists for these temperatures, what architecture would you suggest for a robust industrial design?
*Would an FPGA-based approach (with PCIe/USB IP cores) be the standard here? *Or perhaps an Industrial MPU/SoC (e.g., i.MX8, Sitara) acting as a bridge?
I would appreciate any leads on specific MPNs or proven block diagrams for this data path in harsh environments.
Thanks!
joeyd999
Joined Jun 6, 2011
6,266
I find Grok to be extremely useful for these kinds of questions, either for narrowing down possibilities, or opening up further avenues of investigation. Nothing below is confirmed. YMMV.
No readily available off-the-shelf single-chip industrial-grade PCIe Gen3 (x2/x4) to USB 3.2 Gen1/Gen2 bridge IC exists in high-volume consumer/distributor channels for the exact NVMe/UAS use case, but one strong candidate does exist on paper from JMicron.
The widely used commercial bridges you mentioned (JMS583, ASM2362, RTL9210/RTL9211) are indeed spec’d only for 0°C to +70°C in their standard grades (G/H). However, the JMicron JMS583 datasheet explicitly defines industrial-temperature variants (suffixes I/J for gold- or copper-wire bonding) rated for Ta = –40°C to +85°C. These support PCIe Gen3 x2 lanes → USB 3.2 Gen2 (10 Gbps) with full NVMe 1.x/2.x passthrough, UAS, TRIM, S.M.A.R.T., and power-management features exactly as needed.
  • Availability note: These I/J grades are not stocked on Digi-Key/Mouser/Amazon like the commercial versions (they are produced for industrial/OEM customers). You must contact JMicron directly or an authorized FAE/distributor for samples/qualification. If your volume is low, lead times or MOQ may be an issue.
  • ASM2362 and RTL9210/9211 do not list –40°C to +85°C grades in public datasheets (ASM2362 tops out around case temp +85°C but is not guaranteed ambient –40°C).
No other single-chip USB 3.2 Gen2/Gen1 → PCIe Gen3 NVMe/UAS bridge (from ASMedia, Realtek, Microchip, Diodes, etc.) meets the industrial temp requirement today. Older PCIe-to-USB 2.0 bridges (Diodes/Pericom PI7C9X440/442SL, Broadcom/OXPCIE200) do have true –40°C to +85°C ratings and are easy to buy, but they are limited to ~480 Mbps and are the wrong direction/speed.
Recommended Alternative Architecture for Robust Industrial Design
If the JMS583 I/J variant is unavailable or disqualified for your program, the standard and most robust path is an industrial-grade MPU/SoC acting as a smart bridge. This is far more common (and supportable) than a pure-FPGA solution in industrial embedded designs.
Best choice: NXP i.MX 8 series (especially i.MX 8M Plus or i.MX 8M Mini industrial/Automotive-qualified parts)
  • Temperature: Many i.MX 8M variants are qualified –40°C to +85°C (or even +105°C) with full industrial qualification.
  • Interfaces: PCIe Gen3 root-complex (x1 on 8M Plus; some family members offer x2/x4) + USB 3.2 Gen1/Gen2 OTG/device controller.
  • How the bridge works:
    • Connect your NVMe SSD directly to the i.MX8 PCIe port (use an industrial-temp M.2 NVMe SSD such as ATP, Innodisk, or Swissbit –40°C to +85°C modules).
    • Run Linux (NXP’s Yocto BSP is excellent and long-supported).
    • Use standard nvme driver + USB gadget framework (g_mass_storage or gadgetfs + f_mass_storage with a LUN pointed at /dev/nvme0n1, or the newer UAS gadget support).
    • Result: the SoC presents the NVMe SSD as a USB Mass Storage / UAS device to the USB 3.2 host.
  • Why this is robust: Full OS control (firmware updates, error handling, power management, logging, watchdog), long-term silicon availability, and industrial supply chain. Bandwidth on PCIe Gen3 x1 is ~985 MB/s theoretical — sufficient to saturate USB 3.2 Gen2 in most real-world workloads.
  • Sitara AM6x / AM5x family (TI) is a close second if you prefer TI ecosystem (also has –40°C to +85°C / +105°C grades and PCIe Gen3 + USB 3.x).
FPGA-based approach (with PCIe/USB IP cores) This is technically feasible but not the standard or recommended path for this use case:
  • You would need a mid-range industrial-grade FPGA (e.g., Xilinx Artix-7 / Kintex-7 or Intel Cyclone V / Agilex –40°C to +85°C speed grades) with hard PCIe Gen3 root-complex IP + USB 3.2 device IP (or soft-core USB).
  • Then you must implement the NVMe → UAS/Mass-Storage protocol translation in RTL or soft-core firmware.
  • Downsides: Extremely high engineering effort and cost (PCIe RC + NVMe command handling + UAS state machine), power/heat, certification, and long-term support headaches. Only choose this if you already have FPGA expertise in-house or need ultra-low latency / custom protocol features. Most industrial designs avoid it for simple storage bridging.
Quick Recommendation Summary
OptionFeasibilityTemp RatingComplexityCost / AvailabilityRecommendation
JMicron JMS583 I/JHigh (datasheet)–40 to +85°CLowMedium (contact JMicron)Primary choice if you can source it
i.MX 8M (NXP) SoC + Linux gadgetVery High–40 to +85°C/+105°CMediumGood (standard modules)Best robust industrial path
FPGA + IP coresPossibleYes (select grades)Very HighHighOnly if you need custom logic
USB 2.0 industrial bridgesEasy–40 to +85°CLowHighToo slow — avoid
Next steps I suggest:
  1. Contact JMicron (or your local distributor) and ask for the JMS583 I/J datasheet + availability/qualification data. This is the simplest drop-in if it works for your program.
  2. If that falls through, prototype with an i.MX 8M Plus industrial module (MYIR, Variscite, or Toradex offer ready COMs) + industrial NVMe SSD. The software side is straightforward with NXP’s BSP.
  3. For a full custom board, pair the SoC with an industrial-grade M.2 connector and power circuitry.
This combination gives you a reliable, long-lifecycle industrial solution without reinventing the wheel. Let me know your volume, power budget, or form-factor constraints if you want more specific part numbers or reference designs!
