I am currently using h-bridge configuration for an inverter. I get lots of noise when I apply voltage to it. Is there a way to suppress the noise ?
Here the schematic isSchematic? How is anyone but you to know what your circuit looks like to give opinions and help?
I am using differential probe.How are you connecting your scope? Are you using a differential probe to measure accross you output load? You cannot connect the scope ground directly to the output or the earth of the scope will short the inverter output. Thats what you were doing in proteus also, it looks to me like you've shorted one of the phases.
It switches the mosfets. i can see filtered signal as well but when i go above 6 volts, my power supply makes a humming noise like a short circuit and lower cycle is totally distorted.
Can you zoom in there appears to be a lot of high frequency fuzz there so you need to zoom in on perhaps one or two cycles to see whats going on. The filter needs to be the last thing you add once you know everything else is right. One thing i notice on your white trace is that for some reason your always going past the zero crossing point (the dead time between cycles) within a cycle. it should be positive for one half cycle and negative for the other. I also note its not symetrical around your dead areas which also wouldn't be correct to generate a sine wave.The purple one is the pwm from h-bridge. It represent the blue signal on proteus(please see the proteus photo). Just removed the inductor. I still have the same problem. When I increase the voltage, it makes a humming noise and seems to be a short circuit.
If you removed the IR2110 then you've removed the driving of the H bridge. Thats perfect.I just applied 25 volts. Never reached that before. If I could remove the spikes, I would probably see the sine wave. I removed one of the IR2110 which controls the 50khz frequency spwm. All the spikes on pwm signal dissappeared.
