StayatHomeElectronics
- Joined Sep 25, 2008
- 1,073
Can you put the INVERT on B instead of A?yes, didn't have much of an affect here
Good question.Thank you very much. I also just simulated. It works. What are those spikes? Are they important?
Yes, its an HBridge Driver so will have the same functionality.I ordered PCB from China. I will check whether it works in real. I would like to ask a dump question by the way. Can I use h-bridge driver( ir2184) instead of high low side driver(ir2110)? If I can't, why? Last but not least, if I use tl084 for triangular wave generation, what's maximum frequency value I can get?
Yes its the zero crossing point, the point which it goes from positive to negative in the cycle. The inductor in your case creates a back EMF as is resisting the instant reversing of the current of the inductor.spwm signals when it resonates.
