Inconsistency in proteus AC sources and measurement
Yzyma
Joined May 31, 2026
Good day everyone!
I have found some inconsistency in AC source parameters and reading during simulation in proteus.
For example, if I take VSINE device and define amplitude as 220*sqrt(2).1780224883970.png
and then run simulation AC voltmeter will show 220 volts
But oscilloscope shows peak-to-peak 220*sqrt(2) so amplitude is 220/sqrt(2)
does anybody know something about it?
35,177
AC voltage is RMS voltage.
amplitude
= V x √2 / 2
= V x √2 x √2 / ( 2 x √2)
= V x 2 / ( 2 x √2)
= V / √2
BobTPH
Joined Jun 5, 2013
11,647
Good day everyone!
For example, if I take VSINE device and define amplitude as 220*sqrt(2).View attachment 367839
Congratulations! You have discovered how to set a source to a specific RMS voltage when the parameter is peak voltage.
ericgibbs
Joined Jan 29, 2010
21,569
hi Yz,
Welcome to AAC.
Google proteus 220v *sqrt(2)
Note the comment regarding entering 312v if the parsing formula fails
E
Clip:
To simulate a standard 220V RMS AC mains power supply in the Proteus Design Suite using a VSINE component, you must enter the peak voltage in the Amplitude field. [1, 2]
The exact value of \(220 \times \sqrt{2}\) is 311.13 V.
Setting Up the VSINE Source
When editing the properties of your AC voltage source, configure the parameters as follows:
  • Amplitude: 311.13V (or enter 220*sqrt(2) directly if your version supports expressions).
Yzyma
Joined May 31, 2026
Thank you for all your answers
thanks for the book
Don't understand why your 'scope shows 155Vpk when 220Vrms is 311V peak(?).
Yes it was the thing that confused me.
You need to add GND and connect it to the V1 AC source.
Thank you, it solved the problem.
