AlbertHall
- Joined Jun 4, 2014
- 12,660
Does this actually mean that the light IS a cube?Hello All,
Thank you for your responses. "Turn" refers to the orientation of the light itself, not the switch. Think of a cube, for example, if one side is facing up, the cube glows blue; and if the cube is rotated 180 degrees to have the other side pointing up, it glows green. I'm thinking this would require a tilt switch as mentioned, but wanted to see if there are any other ideas. Thank you!
