how to solder a piezoelectric sensor?
drinus
Joined Nov 28, 2026
Hi everyone! I’m having trouble soldering piezoelectric sensors—the cheap, round ones. Soldering to the metal part works fine, but I just can’t get it to stick to the ceramic section; it keeps coming off! Can anyone help me out? Thanks!
I am ASSUMING that the reason for soldering is to make an ELECRTICAL CONNECTION!! Consider that the ceramic segment is an insulator, why would you choose to connect to it?? Certainly not to connect to an insulator.
To attach a conductive material, such as copper foil, to a piezoelectric ceramic, you can either use a very thin conductive glue, OR mechanicly bond copper to the ceramic by using mechanical friction deposition.
