The jumpers are labeled JMP1,2,3,and 4. Only JMP1, 2, and 3 should be installed. If you also installed JMP4, that's a problem.Just double checked and yes it is installed correctly. https://www.easternvoltageresearch.com/content/datasheets/manual_classeplasmaspeaker.pdf
Im in the us so 120v
I am also not sure what a jumper is
Tony, see post #17 which shows the schematic. The 70 VAC CT transformer is external to the board and while I agree and pointed it out the board takes an AC input even though it is labeled In + and In - . The AC is shown fused (3 amp) and goes to a full wave bridge followed by a 2 watt bleeder resistor and one or two filter caps depending on what they send. The board does not use any external DC power.The picture in post #11 shows an AC line connected to the board itself. Are you using an external transformer or are you putting this transformer on the board? Also, look at the picture where the white wire connects to the neutral terminal. Just left of that are some jumpers (labeled JMP2, JMP4 and JMP{can't read}). It's possible they select between 120 VAC and 240 VAC. You said you're running 120 VAC, so if it were mistakenly set up for 240 - that would not hurt the transformer. F41 fuses the power input. F42 fuses the DC input. If you're trying to put the transformer directly to the input (labeled IN- and IN+) you could be dead shorting the transformer, which after a minute or so would cause it to smoke. Those inputs are looking for a DC input. An AC input would be - since AC is positive going one way then negative going - you could be hurting the transformer. At this point we have no idea what that DC input is supposed to be. Some of us may be assuming it's a 12 volt battery backup input, NOT a transformer 12 volt input. And you can't mix AC and DC the way you appear to be attempting to do.
Best advice - if this is a picture of the board - is to put your 120 VAC in at the three terminals at the bottom of the picture exactly the way they've shown it.
run through a fuse and then a bridge rectifier.
Another thing I am confused about is, the fuse it runs through blew but the transformer still fried
5A is a very big fuse for a 2A transforme
I can't understand why a transformer rated for two amps would be fused at five
A good probability since he is doing the populating of the board.If it fried then there must be a problem with the board: Splash of solder shorting something, component the wrong way round, or something similar.
What are the red wires shown plugged into the fuse clip and connected to the input for? Any thing the board needs should be in a PCB trace, not something stuck between the fuse and the fuse holder.It comes.after the fuse but there is a disc thing in between the power and fuse. Not sure what it is called or what it does. The fuse is rated 250v 5a
Saw that. However, a schematic is a piece of paper. The picture of the board shows a (probably) 120 VAC line input. As for the plus and minus "IN" puts - - - if AC then why labeled with plus and minus? The schematic can be the wrong revision - or even a different model. Just looking at what is on the board itself leads me to these questions / comments.Tony, see post #17 which shows the schematic.
I don't know and in my initial comments pointed out that I didn't like the board label where it is clearly an AC input and yes there is also a clearly labeled 120 VAC input and the use of the jumpers is discussed. Most schematics are a piece of paper and most also include Rev levels but in this case all we have to look at is what there is for a schematic and the board images in the book. That is as good as it gets.Saw that. However, a schematic is a piece of paper. The picture of the board shows a (probably) 120 VAC line input. As for the plus and minus "IN" puts - - - if AC then why labeled with plus and minus? The schematic can be the wrong revision - or even a different model. Just looking at what is on the board itself leads me to these questions / comments.
The thread starter was already asked about that. Did you read everything covered before you got here? The use of the plus and minus signs was questioned early on also. Now all anyone has to work with is the board drawing and schematic posted, that's all there is. That is also likely as good as it gets.One other thought - what if BR41 is installed backwards? This IS a kit build, and there is no picture of the solder side of the board.
I checked it, it is fine. I have a neurological disorder and forget things.Also, two of us have mentioned jumpers. The TS 's only response was to the effect of what's a jumper. He needs to review that part of the manual and check his construction. Connecting all 4 jumpers could result in smoke.
