Can someone help me Identify a Fried Capacitor on GEP-F7 AIO 45A FC for Potential Replacement
denni
Joined Jul 18, 2023
65
Hello everyone,
In the photo, you can see the flight controller (FC) of my drone, which is a GEP-F7 AIO 45A. I've encountered an issue with one of the capacitors on the back; it appears to be fried and damaged. The problematic capacitor is circled in red.
I need help identifying the type of capacitor used so I can purchase a replacement. Is there a method to determine the exact type and specifications of this capacitor? I believe it might be an SMD capacitor, but I'm not sure and have little experience with capacitors on PCBs.
Any advice on how to identify and replace this capacitor, i Would be really greatful.
Thanks!
denni
Joined Jul 18, 2023
65
What are the markings on the IC beside the capacitor?
Provide a sharp, well focused closeup photo of that IC.
Can you clarify which markings you're referring to? I inspected the IC next to the capacitor with a microscope but didn't see any writing. Could you specify the exact part or location you're talking about? This will help me provide the information you need
denni
Joined Jul 18, 2023
65
I would replace it with a 0.1 μF - 50V ceramic capacitor without thinking twice. Typical 'bypass' use. Or, remove any of the similar others to measure.
Thanks alot. And what about the dimensions. I measured the dimensions and ive got 1.3 mm x 2.34 mm. But those seems not standard. any idea which one should i get . ( 0603, 0805, 1206, etc.)
Externet
Joined Nov 29, 2005
2,628
...And what about the dimensions...
Just any that has the same size should work. Some are taller. There is metric and non-metric dimensions. Obtaining them is easy and abundant and free canibalizing defunct electronic gadgets, desoldering takes skill, color will usually be brown and used in ´bypass' at supply pins of I.C.s
denni
Joined Jul 18, 2023
65
Thank you so much for your help Sir! I really appreciate it. I'm following your instructions and learning a lot in the process.
About the capacitors, I noticed that the ones on my board are brown, but I have some unused yellow capacitors that are the same size. Can I use the yellow capacitors instead of the brown ones, assuming they have the same capacitance and dimensions?
Externet
Joined Nov 29, 2005
2,628
Do not remember seen yellow ceramic capacitors other than polarized tantalum, but if "assuming they have the same capacitance and dimensions?" Go ahead, try. I would test the board after removing the visually bad one and the one next to it, then place the new ones. There is a good chance they are not essential for the circuit to work. Did you measure the similar capacitors around if 1μF, 10μF, 100μF or ?
denni
Joined Jul 18, 2023
65
Again, Thank you so much for your help, Sir! I really appreciate the time and effort you put into providing this information. These resources and details give me a lot to proceed with. I will take my time to review all the information and apply it.
