Can someone help me to identify these components ?
Fotaje
Joined Dec 19, 2020
5
Hello, dear experts.
Can someone help me to recognize and eventually provide info from where i can purchase the following 2 components ?
Component 1 -> Picture 1,2
Components 2 -> Picture 3,4,5,6
MaxHeadRoom
Joined Jul 18, 2013
30,808
Resistors and rectifier, the part No should be on the diode, the 5watt resistor values are printed on them, all should be available at Digikey.
35,170
Personally i would easily go with 5w for that resistor, I have some that are identical and rated 5W.
I cannot dispute that.
To be conservative, if you are going to reuse the existing resistors, assume they are 3W.
If you are going to buy replacements, get 5W. But I would check them first. 15kΩ 5W resistors don't go bad easily.
byargeon1
Joined Apr 3, 2020
15
If you haven't found or ordered your resistors yet,I will send you the 15k resistors for nothing. A friend of mine passed away last year and I inherited all his new components. I have plenty to help out(as he would too) if u need it. Just throwing out there if you want them.
