I am sure the emitter were not interchanged (reversed), because i checked many times and it was right.
I think all the resistors on this circuit difer exactly 1% from the design values, for 10K resistor i got 9.95K (multimeter) and so on for other resistences.10K have 1% tolerance, 2.7K and 33K have 5% tolerance.
How to check if one real transistor is more acurate than the other transistor?
Where/How exacty do i connect the new resistence and where to check if the voltage is greater or less than zero?
Can you implement that change on LTspice ?
