You can say that again. supa fragile. On my first solar panel build, I turned a few cells to dust...with NOTHING. no pressure, barely touching them and poof.fragile
Where do you get color filters?
One other question I have with using PV cells instead of CDs is the target area. With the cds, I have to be so precise, I would like a target a little bigger, I think a gust of wind could knock this out of line. Is there a way to rig a commercial Laser detector (Think Cobra or whistler radar/Laser detector) to act as my detector and switch the timer? They are fairly inexpensive (40 bucks or so) but may need a larger power supply. Also the problem occurs that we solved with the optocoupler curcuit, I would need the switch to be open when illuminated (detecting) and need to close the switch in abscence of the laser light. Any thoughts?
Did you see my latest posts? (BY the way, you sound like a fun guy at parties(I can just see someone standing by a ballon and you explode them and the jump out of thier skin, could you heat a champaign bottle hot enough to get it to POP?)
I think the detector has a visual alert when detecting the presence of laser energy (led display) I don't have one here to look at but from what I've seen there is an audio that can be silenced and a visual alert.
I don't think I need that much power. Anyway, what do you think of a aluminum foil reflector cone around the cds? Inside my detector casing I don't get much ambient light, if I make the cone real small, all the laser light should get captured and reflected into the cds, hopefully alleviating my aiming problem.
The problem I am seeing has more to do with the accuracy needed shooting the CDS. The unit works fine, as long as the laser is pointed exactly right, but outside, with environmental conditions, I think i will need a bigger target, not as affected by jiggle. Maybe a silicon photodiode laser light detector (Optek part number OP913SL)
