Facing an unexpected voltage drop across output
Saurabh20
Joined Feb 1, 2022
9
Hello all,
I am using a Step-Down Converter (Part Number: TPS543C20RVFT from TI) set up in a Two-Phase Master-Slave configuration on board. I feed the input of 5V and expect 0.85V at the output. During startup, the requirements are met, but after configuring the program on the board, I am facing a drop up to 0.79-0.8V at the output. Are there any methods to overcome this? Need your suggestions to find a solution to this issue. Below is the schematic design image.
Regards,
Saurabh
DickCappels
Joined Aug 21, 2008
10,661
Are you saying that your output seems to be about 50 millivolts low?
If so, how much current is your load drawing?
How much if this design is new?
Alec_t
Joined Sep 17, 2013
15,160
Then logically there may be an error/problem in the configuring.
I've no experience with that IC, or master-slave configuring, but unless there is an exact match of the component values in the two channels of the converter, could there be a feedback conflict which the ICs resolve by going into limp mode?
Saurabh20
Joined Feb 1, 2022
9
Well programming-wise that's the requirement, it takes a lot of resources to function fully so basically it will not be changed. As far as the design goes, I have followed the design recommendation from TI, and also picked components as per rec. Limp mode is something I've not experienced, does it come programmed or it is a general case?
DickCappels
Joined Aug 21, 2008
10,661
50 millivolts divided by 80 amps…
If you are concerned about such a small voltage drop at that kind of current you have to be very careful about the resistance of wiring, routing of the output, ground loops and where you sense the output voltage.
There is some science and a lot of art required.
