Hello all,
I am using a Step-Down Converter (Part Number: TPS543C20RVFT from TI) set up in a Two-Phase Master-Slave configuration on board. I feed the input of 5V and expect 0.85V at the output. During startup, the requirements are met, but after configuring the program on the board, I am facing a drop up to 0.79-0.8V at the output. Are there any methods to overcome this? Need your suggestions to find a solution to this issue. Below is the schematic design image.
Regards,
Saurabh
Regards,
Saurabh
