MisterBill2
- Joined Jan 23, 2018
- 28,462
OK, and indeed the ripple would also be divided, So how about a capacitive divider? Or maybe NOT!I understand what you are saying - but the problem with having the capacitor on the low voltage side, especially for a high voltage supply of -6kV like mine, the desired ripple of 0.1V is also divided down by the resistive divider circuit, which has a voltage ratio of 2000 in my case. A 3V reference voltage for a -6kV output. So that 0.1V is basically within the range of noise when divided down by that much. So the only way to extract the actual voltage ripple from the circuit is to have the isolation capacitor on the high voltage side - but for some reason, in my simulation, you may see that it does let some DC through the isolation capacitor, which doesn't make sense because of how capacitors are supposed to work!
The unfortunate reality is that real capacitors do have some leakage, and that will cause problems. one option might be to provide a low impedance drain that would be a resonant circuit at the ripple frequency. But that would distort the ripple into a sine wave, so that may not work adequately.
How long do you need to examine the ripple waveform? A small battery powered transmitter floating at the output voltage could provide excellent isolation, and avoid any DC offset issues.
