Erase positive signal in GND from main power
Goxeman
Joined Feb 28, 2017
176
Today I tried to capture the noise but I wasnt able, I dont know if it is too high or too low or I just wasnt able for some reason. But I took some pictures of the screen of the scope after measuring the voltage of the power in different points, just to see how the filter and the DC-DC behaves and if the problem is mitigated or not. Voltage of the truck battery should be 24V but a range between 22V and 28V could still be acceptable.
Please check the pictures and tell what you think and what would you do, I am sure that the noisy ground is related to this. Please note that the measures have been taken in different moments, the best thing would have been the chance to compare all measures at the different points at the exact same time
Picture 1 - When starting the power truck's electrical system
Picture 2 - Truck is off, the electrical system can be turned on, so is using the battery's energy. Voltage is stable around 24V but when a motor (no the truck's engine) and coils are on voltage goes down and then a bit up. This is normal, dont pay attention to the -24,8V, each square represents 5V so the lowest voltage was around 14V
Picture 3 - Truck is on and energy system is on, this measure was made at the PCB input, this is the power input of the PCB
Picture 4 - Truck is on and energy system is on, this measure was made after all PCB filtering, right before the DC-DC converter
Picture 5 - Truck is on and energy system is on, this measure was made after the DC-DC converter with fixed output 3,3V. I dont understand why the long vertical line
MisterBill2
Joined Jan 23, 2018
28,615
I see that the truck electrical has both kinds of noise, lower amplitude higher frequency and much greater amplitude transients. The high frequency low amplitude stuff is not that hard to filter, but those transients will be a serious challenge.
Goxeman
Joined Feb 28, 2017
176
What do you think that I should add to my design? For the transients I am I theory already using an unidirectional TVS diode of 36V, should I use additionally a MOV?
Should I use Y capacitors? With this matter of noise filtering I am bit lost, I dont have all tools and knowledge I would like
MisterBill2
Joined Jan 23, 2018
28,615
I would avoid using a MOV since they often become stuck in the low resistance state after absorbing a transient spike. That would require a replacement of the mov, which is probably not a part of your business plan.
And it is still not clear to me what the application of this filter module is intended to be. The application of a product usually helps decide the acceptable cost point for that product.
Norfindel
Joined Mar 6, 2008
326
And what's the voltage at the output of the dc-dc converter like? Is the noise present at the output too? Maybe capture input and output voltages at the converter?
Goxeman
Joined Feb 28, 2017
176
Ok, TVS diode wont have that problem. Thanks for the tip. The application I wanted to be the control of any motor or pump that could be mounted on a truck
Output voltage it should be 3,3V and I have to say that is really stable the output voltage but still not completely stable
MisterBill2
Joined Jan 23, 2018
28,615
WAIT!! Post 26 states that the application is the control of any motor or pump on the truck. Those devices really don't care about noise. And not many will run on 3.3 volts. Something here is very incorrect.
Goxeman
Joined Feb 28, 2017
176
I will refer you to here: https://www.littelfuse.com/~/media/...utomotive_tvs_diodes_application_note.pdf.pdf Littlefuse has another.
Also look at the LT/Analog devices surge stopper devices. There is both a positive an negative pre-regulator with uV noise performance introduced by AD. The positive one: https://www.analog.com/en/products/lt3042.ht They can be paralleled.
Thanks for the links but second link doesnt work, maybe you missed some while copy/paste? First link is useful, I already read about. In fact I read about the SLD8S30A Little Fuse TVS diode but the TVS diode that I am testing is the STmicroelectronics SMT633CAY
https://www.littelfuse.com/~/media/.../littelfuse_tvs_diode_sld8s_datasheet.pdf.pdf
https://www.st.com/resource/en/datasheet/sm6ty.pdf
The Little fuse one is bigger, unidirectional and much more expensive part while the STmicroelectronics is smaller, bidirectional and cheaper. Obviously the characteristics and specifications of the Littlefuse one are much better but I evaluated it with a friend of mine and at the end we considered that it wasnt worth it. The littlefuse one peak pulse current specification is much better mainly because of its size I guess. Another important thing that I considered it was the response time but I couldnt see that specification within the STmicroelectronics part
What about trying this kind of filter before the dc-dc converter?
The video it is interesting, still it is the first time I see this recommendation to decrease the ripple. If using the Darlington in one package, this has a component count of at least a 3 components, not very costly but still I am not very convinced about the solution. Maybe someone else can give their opinion about this
Yes you are right, nothing works with that voltage. My circuit should be controlling relays within the PCB so the output of the relay is the one controlling the truck devices. My correct answer should have been that the application is to control a motor or pump on the truck through a relay installed within the PCB
I have been thinking, would it make sense to use TVS diode (one at the input main power) and secondary TVS diode at the output of the DC-DC converter? Or right before the DC-DC converter?
Fixed link in original post "add "ml" as in html. Sorry.
Corrected here again:
Also look at the LT/Analog devices surge stopper devices. There is both a positive an negative pre-regulator with uV noise performance introduced by AD. The positive one: https://www.analog.com/en/products/lt3042.html They can be paralleled.
MisterBill2
Joined Jan 23, 2018
28,615
It is becoming more difficult to imagine why anything that sensitive to the slightest noise voltage, and operating on that very low 3.3 volt level, would ever be considered for operation in a big truck. Many others have implemented very reliable systems running off of the 24 volt system and have not suffered problems. Truck systems do need to be reliable.
Goxeman
Joined Feb 28, 2017
176
Within the PCB there’s for example a MCU which works at 3,3V but it could also be 5V, in any case the noise would be affecting it. I would also like to implement some Bluetooth features for example and the base for it all is a good and reliable system in general as you say
If others have implemented very reliable systems running at 24V I would like to see how it was done because it could help me out. I’m just trying to do the same
Thanks
if I have to feed you better, look here: https://www.analog.com/en/products/...opper-overvoltage-overcurrent-protection.html
TVS diodes are old technology compared to this.
The LDO regulators that i linked to will smooth out switching regulators for less noise.
Aside from surges, sags and reverse polarity events and alternator related power problems, any sensors are ratiometric. They don;t depend on a stable reference. The A/D is referenced to the power supply or more typically 1/2 the power supply. Now if you have a 5V nominal supply. 1/2 the supply is NOT 2.5V. It's 1/2 the real-time value of the power supply.
Sensors ARE NOT 0-5V although they may be described that way. Zero and the 5V rail is unattainable. They may be 50-100 mV away from the rail, but they CANNOT equal the rails.
Goxeman
Joined Feb 28, 2017
176
Thanks for the correction, I just saw it. It is true that LDO are better with power supplies like with the needs I am searching related to noise rejections and clean power source but I discarded it because they less efficient (maybe you will correct me about this because it is also true that I have just always used simple LDO with fixed output) and also they dont admit so high input for a low output. In this case I need something that can take anything from 12-24 trucks, this means for exaple the part that you just proposed it wont be valid because max input voltage is 20V. Also the current specification is lower than most DC-DC converter and for my application 200mA it could be ok but very close to the maximun current use of the whole PCB
I did just checked whats on the market related to LDO and that could take a max input voltage from 33V and more and there is not much that also have automotive qualitification like AEC-Q100
I could always reduce voltage to 8V with a DC converter and then use a LDO to reduce to 3,3V
I am a total ignorant related to this ICs, I didnt know about them
MisterBill2
Joined Jan 23, 2018
28,615
One more question: When you measure all of that noise on the negative power connection, where is your measurement reference point? All voltages are relative to some point, and so now I am wondering about what reference you are measuring this noise voltage against. I think that there was a bit of discussion at one point but now I am really wondering.
Goxeman
Joined Feb 28, 2017
176
The pictures of measures I took are from negative to positive, I mean, I measured the differential of potential. I didnt measure the noise on the ground plane even if I started this post asking about how to erase noise from ground; I was refering to suppression of negative transients because as far as I think that I was taking wrong measures initially
