Today I tried to capture the noise but I wasnt able, I dont know if it is too high or too low or I just wasnt able for some reason. But I took some pictures of the screen of the scope after measuring the voltage of the power in different points, just to see how the filter and the DC-DC behaves and if the problem is mitigated or not. Voltage of the truck battery should be 24V but a range between 22V and 28V could still be acceptable.
Please check the pictures and tell what you think and what would you do, I am sure that the noisy ground is related to this. Please note that the measures have been taken in different moments, the best thing would have been the chance to compare all measures at the different points at the exact same time
Picture 1 - When starting the power truck's electrical system
Picture 2 - Truck is off, the electrical system can be turned on, so is using the battery's energy. Voltage is stable around 24V but when a motor (no the truck's engine) and coils are on voltage goes down and then a bit up. This is normal, dont pay attention to the -24,8V, each square represents 5V so the lowest voltage was around 14V
Picture 3 - Truck is on and energy system is on, this measure was made at the PCB input, this is the power input of the PCB
Picture 4 - Truck is on and energy system is on, this measure was made after all PCB filtering, right before the DC-DC converter
Picture 5 - Truck is on and energy system is on, this measure was made after the DC-DC converter with fixed output 3,3V. I dont understand why the long vertical line
