djsfantasi
- Joined Apr 11, 2010
- 9,237
It should be the same as the APM supply. The grounds of the APM supply and the 12V supply need to be connected as well.
Not exactly the same. Your second MOSFET isn’t a logic level MOSFET and hence your pull up resistor is to the solenoid power supply. All MOSFETs in this circuit are logic level and need a lower voltage on the pull up.Its the same circuit as I posted earlier (post #22)
Ok, I can do it. Thank you again. Gonna buy those components, build it and show the results here.It should be the same as the AMP supply. The grounds of the AMP supply and the 12V supply need to be connected as well.
Ok, gonna see which mosfet I can buy and set the circuit accordingly.The post #41 circuit will work if the power MOSFET is a logic-level type. If it's not, connect the top 10k resistor to +12V instead of to +5V.
(BTW, when drawing circuits, get into the habit of labelling each component, e.g. R1, R2 etc. It makes it much easier to discuss the circuit.)
My point was that it is easier to invert the signal polarity in software (since it is custom software already) than adding external parts, no matter how few.Or use a 2N7000 logic level n-channel MOSFET to invert the logic
Why? I see no reason for the resistors.Place 100Ω resistor between the APM output and the 2N7000 gate, with a 10kΩ resistor from the 2N7000 gate to ground.
Better to move the load to the drain so the FET acts as a saturated switch rather than a source follower. The follower configuration will decrease the voltage across the load by several volts.I was over thinking, you can use the P Mosfet like this:
Actually, if you connect the left side of the 10 K resistor to the +12 V, you no longer need a logic-level FET.So, like this?
If I need to use a PNP or a NPN, how would it be?The post #41 circuit will work if the power MOSFET is a logic-level type. If it's not, connect the top 10k resistor to +12V instead of to +5V.
What calculations would be needed for a BJT?UPDATE: You have many ideas presented to you. I’ll try to summarize them.
- A solution using MOSFETs is a preferred solution, as using BJT transistors requires more complex calculations.
- You can switch either the positive voltage (high side) or the ground connection.
- Switching the high side is done with p-channel MOSFETs; n-channel MODFETs switch the low side.
- You can use a daisy-chained MOSFET to invert the logic.
If you want to stay with the low=on / high=off logic polarity, then two NPN transistors in series will work. The second transistor is the load driver, emitter to GND, collector to the load, load to +12 V.If I need to use a PNP or a NPN, how would it be?
We don’t know enough about the device providing the signal. Hence, a 100Ω resistor protects the APM.My point was that it is easier to invert the signal polarity in software (since it is custom software already) than adding external parts, no matter how few.
To use BJT transistors, you’d still need two in series. And they’d require base resistors. You’d need the maximum current draw of the solenoid as well as the voltage into the base. Divide the current by 10 or 20. Then, given the base voltage and the calculated current, use Ohm’s law to calculate the base resistor. Repeat for the first transistor, using the calculated current (/10) and divide it by 10 or 20 again. Repeat applying Ohm’s law to get the second base resistor value.What calculations would be needed for a BJT?
Where? In which circuit?If I need to use a PNP or a NPN, how would it be?
Post #1 looks pretty clear to me. The driving signal is a +5 V source, which is way below most power MOSFETs max. Vgs rating of 20 V. Also, as this is not a switching power supply or motor controller that must meet european or MIL EMI rules, I don't think the occasional few microseconds of gate voltage ringing is going to hurt anything so a damping resistor is not necessary.We don’t know enough about the device providing the signal. Hence, a 100Ω resistor protects the APM.
In this application, yes. I think the odds are virtually zero that the uC output is an open collector PNP that would require an external pull-down resistor to GND. A pulldown resistor provides no additional functionality, and are a (very) small but unnecessary additional drain on the battery.It is a fairly common practice to use pull-up or pull-down resistors on MOSFET gates. Do you believe they are unnecessary?
How would the circuit look, please?Actually, if you connect the left side of the 10 K resistor to the +12 V, you no longer need a logic-level FET.
Please add reference designators to your schematics. It makes component discussion much easier and more clear.
I'll go with MOSFET, thanks.To use BJT transistors, you’d still need two in series. And they’d require base resistors. You’d need the maximum current draw of the solenoid as well as the voltage into the base. Divide the current by 10 or 20. Then, given the base voltage and the calculated current, use Ohm’s law to calculate the base resistor. Repeat for the first transistor, using the calculated current (/10) and divide it by 10 or 20 again. Repeat applying Ohm’s law to get the second base resistor value.
Then, there is the whole issue of picking a standard resistance value for each of the calculated resistances.
The MOSFETs simply can use 10kΩ pull-up or pull-down resistors.
And depending on what’s driving the MOSFETs, you may not need that 100Ω resistor. It’s just there to protect your circuitry. And anything from 100Ω to 1kΩ will probably work.
While these resistor values work for many MOSFET circuits, with BJTs the resistance values are fairly critical and must be calculated for each circuit.
Can I use the same BJT model in both positions?
