Yes. This is known as a 'level-shifter'. I suggest you read up about that. In the post #13 circuit M1 is being used as a level-shifter, so that a 5V signal can control a 12V device.Can I use another transistor to amplify the APM signal to 12 V?
Thats how Falstad app symbolized them mosfetFET symbols?
Or use a 2N7000 logic level n-channel MOSFET to invert the logic and drive an n-channel logic level power MOSFET (like the one linked) to power the solenoid. This particular power MOSFET can switch up to 30V at 60A - more than enough for your needs. Yet it only needs 5V to switch on. It’s use is common with microprocessors.In post #1, a low signal turns on the magnet. If you can reverse this logic polarity such that a high signal turns on the magnet, then all you need is an n-channel, logic-level power MOSFET (plus the diode across the coil). No resistors, no capacitors. And no 555's (inside joke).
ak
I want the solenoid to disable when the APM send the +5 V.Just to be clear... when the APM sends +5V, what do you want the solenoid to do?
You may not need the level shifter...
Like this?Or use a 2N7000 logic level n-channel MOSFET to invert the logic and drive an n-channel logic level power MOSFET (like the one linked) to power the solenoid. This particular power MOSFET can switch up to 30V at 60A - more than enough for your needs. Yet it only needs 5V to switch on. It’s use is common with microprocessors.
Place 100Ω resistor between the APM output and the 2N7000 gate, with a 10kΩ resistor from the 2N7000 gate to ground. The 2N7000 source pin connects directly to ground.
The drain of the 2N7000 connects to the gate of the power MOSFET and via another 10kΩ resistor to the 5V supply.
Then, the source of the power MOSFET connects to grou nd and the drain of the power MOSFET connects to your solenoid and diode.
With low signal from the APM, the solenoid is activated. A high signal from the APM de-activates the solenoid.
Thank you. Would not that cause problems because of the voltage difference?I was over thinking, you can use the P Mosfet like this:
The second 10k resistor (drawn above the 2N7000) is wrong. It should go to the 5V supply of the APM. Not to the signal. It’s purpose is to pull up the gate of the Power MOSFET when the 2N7000 isn’t connecting the gate to ground.Like this?
NopeWould not that cause problems because of the voltage difference?
Except P MOSFETS are used to switch the high side. As such, you’ve drawn the load on the wrong side of the FET. You are using a P-channel MOSFET to switch to ground. Your schematic won’t work.I was over thinking, you can use the P Mosfet like this:
.... but that can put 12V on the micro's output pin. It might not like that!you can use the P Mosfet like this
RIght, well I was assuming when the digital IO of the arduino triggered low, it is grounded.... but that can put 12V on the micro's output pin. It might not like that!
Scratch that circuit, it wont workWould not that cause problems because of the voltage difference?
So, like this? (Can I connect this to a 5 V BEC output? I mean, can it be connected to any constant source or need to be in the APM suply?)The second 10k resistor (drawn above the 2N7000) is wrong. It should go to the 5V supply of the APM. Not to the signal. It’s purpose is to pull up the gate of the Power MOSFET when the 2N7000 isn’t connecting the gate to ground.
Thanks for drawing that out. I’m away from my laptop and haven’t figured out how to draw schematics on my iPhone.
Thread starter | Similar threads | Forum | Replies | Date |
E | Which push button switch do I need? | General Electronics Chat | 2 | |
A | What's this circuit does? An electronic switch? | General Electronics Chat | 3 | |
S | Weld electronic remote on standard wall switch | General Electronics Chat | 31 | |
D | electronic switch RCES 105P | General Electronics Chat | 1 | |
R | Electronic Switch | General Electronics Chat | 3 |
by Aaron Carman
by Jake Hertz
by Jake Hertz
by Aaron Carman
