Any clue that brings me closer to solving this problem is thoroughly appreciated... thanksI might have given you an idea but I didn't give you any hard numbers.
Across the coilHmm, Where you measuring with respect to ground or across the coil?
Not just a pretty face.I guess I did contribute something. ronv landed exactly on my worst doubt.
I'm going to double check on that, I had a Lab that owns me a favor test it for me, so I wasn't there when it happened.I'm still trying to figure out how there is only 3.8 amps with 12 volts across the coil.
Not as pretty as joeyd999Not just a pretty face.![]()
Now that ain't fair... not all of us were born with his looks...Not as pretty as joeyd999![]()
Actually, I did measure the wire diameter with a caliper (after destroying a sample using a mill), and it matches exactly that of 23 ga light film coated (0.0235"Ø @ 0.02031Ω/foot) given in page 9 of this document. If you look at post #1, I calculated 30.53 ft total from the coil's geometry that I also carefully measured (it has a mean diameter of 1.166" and a height of 0.470", and I also physically counted the number of turns), and it also matches exactly the resistance value of 0.62Ω that I measured. That's 0.02031Ω/foot X 30.53 = 0.6200643ΩHere's a recalculation on the wire:
24 ga "heavy film coated" meets the measured size exactly.
that's 25.67 ohms per 1000 ft.
Mean radius is 1.16 inches
mean circumference is 7.326 inches
100 turns is 728.8 inches
which is 60.7333 ft
times 0.02567ohms is 1.56 ohms.
12V/ 1.56 ohms is 7.7 amps
Not a lot of difference compared to 3.8 amps.
If your measurement was for naked wire, that's 23 ga at 49.26 ft/ ohm or 0.0202 ohms per foot
and that's 1.233 ohms allowing 9.7 amps.
Something is very wrong.
Well... yes, I do have one of those valves available. Are you suggesting I approach this thing starting with an educated guess, and then proceed with trial and error?Yes, inductors change inductance with frequency. It depends a lot on the core, and a solenoid is a moving core.
They also fail at high frequencies because of internal capacitance, but that's usually in the MHz range.
Wouldn't this be so much easier if you had one of those valves to plug some voltage into?
Well, if somebody botched something, then that would be me..I guess I'm assuming you can measure the resistance and inductance if you have all day to do it. I think you still need to go re-run the voltage and current checks that somebody botched.
Would you mind clarifying? My knowledge of analog electronics is quite limited.Ahh, I think I see it. The voltage isn't exactly on ground to start with - maybe 10 volts. Then this would fit pretty well.
| H | Questions on RFIC and Electromagnetic design | Homework Help | 1 | |
| R | Opinions on this Waveform Generator | Test & Measurement | 16 | |
| R | waveform generator | Technical Repair | 35 | |
| A | Electromagnet | General Electronics Chat | 92 | |
| R | Electromagnet Turns And Same Field generated?? | General Electronics Chat | 5 |
