Effect on R2R ladder
YoGMan
Joined Sep 20, 2017
76
I want the leds to light corresponding to the binary number I input, How can I do this without affecting the output?
38,503
It will give incorrect outputs and with the values shown the LEDs won't light either as there won't be enough current through them.
I though the same at first , but look at the circuit again.
The LEDs are switched between 10V and ground.
They will light up properly and have no effect on the DAC output voltage.
YoGMan
Joined Sep 20, 2017
76
Hello guys , thanks for the replies. I know it should not affect the output buy im having a drop in output voltage when I add the leds and don't know why.
OBW0549
Joined Mar 2, 2015
3,566
Is your 10 volt supply stable, the same voltage whether the LEDs are on or off?
Are you using actual switches, like toggle switches, or are your "switches" actually semiconductor devices (transistors, MOSFETs, etc.)? If the latter, be aware they will drop some voltage across them, even when on.
Can't think of anything else...
YoGMan
Joined Sep 20, 2017
76
Instead of switches, I'm using arduino( and 5 V supply) to input the binary signal .I also need to connect the a 7-seg decoder to display the decimal number on 7 segment.Just for testing I'm using arduino, I'll later replace with toggle switches.I also tried adding opamps as buffer to the inputs and add the leds to +ve terminal- again there is distortion in the output signal - it goes high, then low again then high.
OBW0549
Joined Mar 2, 2015
3,566
A logic HIGH output from an Arduino port pin (or from any other microcontroller, for that matter) does not go all the way to +5V, and may not go much higher than 4-4.5V when driving an LED. And the more current you draw from the pin, the lower the HIGH output voltage will be. That's why your LEDs are interfering with your DAC accuracy.
38,503
Use a CMOS buffer, such as a CD4050, to drive the network and a separate CD4050 to drive the LEDs.
It should get very close to 0V and 10V when driving the over 200kΩ equivalent resistance of the network.
MrAl
Joined Jun 17, 2014
13,702
How much of a drop?
If there is significant resistance in the 10v power supply line then THAT will cause a voltage drop with LED's because the LED's then draw significant current though the line when before it was just very light current.
Are you by any chance using a solderless breadboard? (also called a plug board).
If so, that could be the problem. The resistance of these boards varies with different makes and models and age.
YoGMan
Joined Sep 20, 2017
76
Thanks for all the answers guys , Yes i'm using breadboard maybe this is the problem.... I've removed the leds and I'm using a 7 seg decoder to display the decimal number on hex display and all is fine - I think I'll have to remove the leds from my project.
MrAl
Joined Jun 17, 2014
13,702
If you ditch the plug board it may work fine just the way you had it. Actually, it should work fine.
GopherT
Joined Nov 23, 2012
8,009
Check if the voltage on your +10V supply drops (even slightly) when an LED lights up. The “internal resistance” of the 10v supply may be fairly high and not intended to be stable power unless it is driving 100k ohm loads.
