Effect of humidity on wood
AlbertHall
Joined Jun 4, 2014
12,663
I have asked this on a woodworking site but got no replies and I know you lot know everything about everything so I decided to ask in here.
I have a wooden clock. The pendulum rod is shaped rather like a question mark, the curved part giving clearance to the mechanism.
The clock needs to be carefully aligned on the wall so the pendulum action is centred but this setting seems to change with humidity sufficiently to stop the clock.
The wood is hardwood veneered MDF. Would changing humidity change the curvature of the curved part of the pendulum rod?
wayneh
Joined Sep 9, 2010
18,183
Yes, almost certainly. You've got yourself a hygrometer.
jpanhalt
Joined Jan 18, 2008
11,087
Wood (dry) swells with moisture. The increase is considerably greater cross grain than along the grain. That's why the recommend wall clearance on walls parallel to the grain is more then walls perpendicular to the grain. Surely the same applies to your pendulum.
Alec_t
Joined Sep 17, 2013
15,163
The with-grain/cross-grain difference mentioned in post #3 probably won't apply to MDF, since the wood particles have essentially random grain orientation. However, it could apply to the veneer. Regardless of grain direction, the wood dimensions will vary with humidity, though I'm surprised the variation is great enough to stop the clock.
MaxHeadRoom
Joined Jul 18, 2013
30,881
MDF is a medium density fibreboard composite, whereas it might swell with excess moisture, this would cause separation of any veneer on the surface, the veneer will typically be of a hard wood and would swell according to the direction of the grain, but this generally results in peeling of the veneer.
Max.
JohnInTX
Joined Jun 26, 2012
4,787
Max.
+1 Having seen it damp around the house, it looks like it's just pressed sheets of paper. Get the end wet and it delaminates into mush. We have it all through our place and it's seriously humidity sensitive. Good woods are as well (ask any guitar player) but not like that stuff.
djsfantasi
Joined Apr 11, 2010
9,237
How is the pendulum sealed?
Since humidity affects the operation of the pendulum, it needs a coat of waterproof sealant to minimize the effects of moisture. Several coats of good quality spray lacquer sealant might resolve your problem.
AlbertHall
Joined Jun 4, 2014
12,663
It is not sealed, nor is any part of the clock. I suspect it would be problematic for the mating surfaces to be coated so I thought it best to leave it all naked.
Do you know, that hadn't occurred to me as a solution. That can be done without interfering with the function at all.
Are all spray lacquers waterproof?
jpanhalt
Joined Jan 18, 2008
11,087
That depends on how mangled the term,"lacquer," has become. An epoxy might be better. Shellac is probably the worse. Why not make a new one out of ash, oak, or whatever real wood you have available? Or, maybe a composite foam sandwich? Model airplanes, particularly sailplanes, use such sandwiches.
wayneh
Joined Sep 9, 2010
18,183
Polyurethane certainly is. The water-based version is really easy to apply. I've also used a sanding sealer product that was very similar - it puts a nice smooth and waterproof coating on wood without feeling like plastic.
BobTPH
Joined Jun 5, 2013
11,677
How thick is the MDF? It is not normally sensitive to humidity like wood is, but if it is veneer over a thin later of MDF I could see the veneer swelling and warping the whole panel.
Bob
AlbertHall
Joined Jun 4, 2014
12,663
Bob
The rod is about 1cm square. The veneer is perhaps 0.5mm.
djsfantasi
Joined Apr 11, 2010
9,237
As others have noted, all are not waterproof. But, check the can label. Most are.
What do you mean by “mating surfaces”? Whether or not is problematic depends on your answer. If the surfaces are to be glued, then it depends on the adhesive. Wood glue may not bond strongly. A polyurethane glue or epoxy joint won’t be a problem. And, one can seal the assembly, after joining.
AlbertHall
Joined Jun 4, 2014
12,663
By mating surfaces I meant the bearing surfaces, gear teeth and the like.
wayneh
Joined Sep 9, 2010
18,183
There is no friction (other than air resistance) associated with the pendulum. It has two screws points on which it sits.
I think just about any coating would make a sizable difference. It just depends on what you have on hand, or wouldn't mind having around for other projects. I've read of people using thinned-down wood glue (PVA) as a 'varnish'. Wax, oil, Thomson's water seal, paint, deck stain, whatever. Any of these would dramatically reduce water migration. I'd use the polyurethane varnish because it's perfect and I always have some around.
AlbertHall
Joined Jun 4, 2014
12,663
Using PVA would be appropriate as it is glued together with PVA.
I have ordered a small tin of polyurethane 'yacht' varnish.
