Danelectro Cool Cat Fuzz V2 Guitar Effect Pedal - No Output ..#2
jvguitars
Joined Jun 7, 2026
The output signal is very weak, almost non existent. I can hear it if I turn my amplifier up very high. I'm troubleshooting with an audio probe. The signal is strong until C4/C6 and if I jumper from there to pin 1 of the LF353 the pedal seems to work more or less normally with all the controls functioning and what seems like normal output. But jumpering across only R7 does nothing. Should I conclude the opamp is bad?
- JS
Hello, did you ever solve the problem. I have the same issue with mine. Thanks
Mod: new thread create, link to old thread.
https://forum.allaboutcircuits.com/...ar-effect-pedal-no-output.182384/post-1673621
