How did you come to conclude that 3525 didnt work. 3525 just generates pulse to gates of Mosfet. And I have 4 IRFP250N in pararell. I have tried to send you my email so that I can send vedio show that it has already worked but seem like this against allaboutcir.. policy which want us to use text comunicate just right here in the thread only. I have seen an old real machine, they use opamp 741 to generate frequency and a pair of conjugate transistors
(like you would find in class D amplifier) to expand the strenght of the signal. The pair makes emitter follower circuit. And the amplified signel either go to base of transistors or gate of Mosfets.
So far my machine work with kerosene. I tried on diesel it also works (i dont have submerge system) and I have found out the diesel can also catch fire. The explosion at the middle of electrode can create high pressure which can ignite diesel. I have just started trying a little bit with water. But problem I found so far is this your generator have to work a bit harder because leak of electricity due to electro-plating. And debris particle seem to be bigger as I sit a magnet close to spark iron dust is traped. So flushing with water is more important than ever. Good side with water is that you can leave the machine work unattend.
Have you tryed your system yet, I reckon the surface quality must be good.
