Duty Cycle for Function Generator
Ally Cat
Joined Mar 28, 2016
80
Hi
I need to buy a function generator for a test. The test requires a duty cycle of 90%. Most of the function generators have a that I looked at have a maximum rating of 85 %. The function generator at my disposable is a 4001A B&K Precision FG. Looking over the data sheet does not specify a duty cycle maximum.
Regards
Alec_t
Joined Sep 17, 2013
15,167
Presumably the 'function' is a simple rectangular wave-form?
How accurate must the timing be?
What frequency and amplitude?
Ally Cat
Joined Mar 28, 2016
80
The frequency can be as low as 1 Hz. The amplitude is 10 Vp.
Accuracy of timing is not important. Just the duty cycle is specified.
38,946
The 4001A B&K Precision FG will not apparently do a 90% pulse waveform.
Do you want to buy a generator or build a circuit to do what you want?
Here's a simple PWM circuit that can be adjusted to a duty-cycle of above 90%.
Ally Cat
Joined Mar 28, 2016
80
This is for an ongoing test that will need to be repeated. I just surprised that a simple thing like a 90% duty cycle can't be purchased. I suppose the circuit will work if using professional test equipment cannot work. What about using a Aurduino kit with an amplifier. Could that not get the same result?
