555 timer with adjustable duty cycle
Alec_t
Joined Sep 17, 2013
15,171
Please post the schematics for the two circuits, with designators for all components, so that we can see and discuss them.
38,952
there is only a few components and you need a schematic for that?
Yup.
Schematics is the language of electronics, not pictures of PCBs or verbal descriptions.
We would have to draw the schematic from your PCB and that's not generally part of the free work we do here.
Are you telling us the circuit was built without a schematic?
Jopee
Joined Jun 30, 2024
41
Yup.
That is from a youtube video by "The Engineering Mindset". Oscilloscope guide.
ulms
Joined Mar 19, 2024
194
Looks like you garnered the wrath of the cranky crew. A picture like that works well enough and is quite clear and straight forward especially for experienced and very talented guys like the above members.
sghioto
Joined Dec 31, 2017
8,765
Can someone explain why the circuit without diodes doesn't work? It still has different paths for the capacitor to charge and discharge. Charging uses left side of the potentiometer and discharging uses right side.
As configured from the image in post #1 seen below, it does work without the diodes to some extent.
100% to appx 30% duty cycle over a short span of the pot.
Then goes to zero output on the remaining travel which is more then 1/2 the total rotation.
Verified on a breadboard.
38,952
You forgot lazy.
I'm not interested in doing the work of drawing a schematic from a layout (although sghioto apparently is :)) .
That's the TS's job.
Jopee
Joined Jun 30, 2024
41
Thanks. I just don't understand why it doesn't work properly.
38,952
Yes. Like it works with the diodes.
Why would you expect it to work the same with or without diodes?
The diodes isolate the charge resistance from the discharge resistance so that the two can independently control their respective times.
Without the diodes, the two resistances interact such that the full duty-cycle range cannot be achieved.
