driving two different color leds with 2 wires only
ScottWang
Joined Aug 23, 2012
7,504
Good questions. It vas idea only. Now I finished simulation. Seems R5 = 1.2 k as current limiter is too big - current is 0.7 mA only.
When resistor R5 = 100 Ohm, LED's current is 20 mA.
According to the theory that the Vf of LED will be less than Vbr(breakdown), so when they connected with pin to pin and one of the LED is reverse the polarity, so no need two diodes, only need the diodes when the LEDs in series with a current limiting resistor and then in parallel together.
Danko
Joined Nov 22, 2017
2,204
Pretty sure he was responding to post #25 by electricspidey, not either of your schematics.
OK. You can see how small LEDs current. And I used in simulation red LEDs. They have forward voltage 2V. How about 3...3.5 V for white LEDs ? I think you need increase voltage for LEDs feeding. Maybe up to 9...12 V.
ScottWang
Joined Aug 23, 2012
7,504
Please, explain me, your questions are about post #24 or about post #33. I am confused.
There was a message replied to -- ElectricSpidey said:
So that wasn't replied to you.
And I mentioned that because the circuit was too simple and could be damage the LEDs, specially when he didn't considering the voltage came from the inputs side.
ScottWang
Joined Aug 23, 2012
7,504
I just thought about a simple issue, if the inputs current is enough to providing what the LEDs need then probably only need one resistor and two LEDS and it's done, what do you think about this point?
Danko
Joined Nov 22, 2017
2,204
You are right. But I follow rule of DickCappels. He said: "Some LEDs cannot tolerate any reverse bias without suffering long term degredation."
https://forum.allaboutcircuits.com/...ifferent-color-leds-with-2-wires-only.143034/
Danko
Joined Nov 22, 2017
2,204
I do not like it. Because for V forward=3V for white LEDs and V inputs = 3.3 V we need to put resistor R = (Vinp - Vled) / Iled then
R = (3.3 - 3) / 0.02 = 15 Ohm. In this case, if line will suddenly shorted we can have fried logic gates.
And more: I am trying to solve problem in general case. Tomorrow they will need to light 300 mA LEDs and my solution will help them.
ScottWang
Joined Aug 23, 2012
7,504
What I thought was that if the inputs voltage are 5V, not 3.3V, because I can't setup the input condition, so it just a thought.
bug13
Joined Feb 13, 2012
2,002
I have a 12V source, 3.3V or 5V only refer to the logic of my MCU.
GopherT
Joined Nov 23, 2012
8,009
The 1k resistor allows a microcontroller signal voltage to manage the PNP just fine.
The design above with a resistor below the bridge screws up signal control of the PNP
mcgyvr
Joined Oct 15, 2009
5,394
I'm pretty sure he said he wanted to do this on the cheap...so to speak.
"I do want to keep the cost to minimum, so I don't really want to use a h-bridge, relay etc"
The cost of a single relay is dirt cheap.. usually less than $2 and done..
They have spent more time (= money) trying to figure out a way to not just spend the $2..
Makes no sense to me to not do it and be done..
ScottWang
Joined Aug 23, 2012
7,504
Good point. I had forgotten about that requirement. I was imagining one light at time being on, and I wasn't thinking about pwm or anything like that.
If all the conditions and requirement didn't write down on the schematic then we will miss this and miss that ... ;)
ScottWang
Joined Aug 23, 2012
7,504
Is this some kinds of commercial product?
If it is not, why you care so much about the cost since many circuits won't cost much?
How many mA that the uC could provides?
Did you see the posted #52, is it doesn't match your application, why?
bug13
Joined Feb 13, 2012
2,002
It’s a prototype at this stage. We are just testing out different part of a design. Could lead to a commercial, I hope.
So the lower the cost, the better.
I totally understand why you suggest the circuit on post #52. In our application, we may need to drive 4 leds instead of 2. (Still two color, but 2 will be in serial). So I may prefer the h-bridge solution.
I can see what your suggested on post #52 is perfect for some other application.
Or maybe it’s the Chinese in me, I always want to do thing cheaper if possible :p
ps: we haven’t settle on a MCU yet
