Driving circuit for Large 7 segment Display
demnikgr
Joined Nov 9, 2019
6
Hello everybody, I could use some help with a project I 'm working on.
I have a up/down counter, to be specific its the Velleman kit K8035.
It 's working fine, but now I have to make it work with Large 7 segment display, KYX-40101AS.
Can anybody help with the circuit I need to drive those Big Display and make them work with the K8035 kit?
Thank You!
djsfantasi
Joined Apr 11, 2010
9,237
Thank You!
Sorry, I refuse to view PDFs anymore. My cell phone OS no longer displays PDFs unless you download them locally. Which #^*+ up my phone.
It is not a difficult problem. Based on the specs of what the device CAN operate and the corresponding specs of the large display unit, I’d just build a driver for the obvious higher current. A transistor driver or MOSFET driver.
dl324
Joined Mar 30, 2015
18,476
Welcome to AAC!
I think you're going to have problems.
The kit displays are on a 5V supply.
The datasheet for the large LEDs shows 5 LEDs in series for each segment.
The datasheet gives forward voltage information, but it's unclear if it's for each diode or for 5 in series. I'd assume the former.
Could you confirm whether the segments will turn on with the stated voltage under VF?
demnikgr
Joined Nov 9, 2019
6
Dear djfantasi thanks for the fast reply.
can you see photos? I tried the ULN 2803A without success... I not sure how to do the circuit and the components ...
demnikgr
Joined Nov 9, 2019
6
Welcome to AAC!
Hi dl324, thanks for replying!
Well the Voltage I tried and is working is 12V to light the segments and I used a 2,2k resistor on +v...
djsfantasi
Joined Apr 11, 2010
9,237
First, you need to determine from the display kit specs the current draw of a single segment. Call that Is. Then, calculate the total maximum current draw by multiplying the segment draw by 7. Call it It
The transistor at the top of the second schematic must be able to handle this amount of current. The resistors R9-R12 must be resized to supply 1/10th of that current to the transistor base. Call 1/10th of the current I’d. To calculate the resistance value, you need the voltage supplied by the pins DY1-DY4. Call that Vd. Then the resistor is equal to the next size greater than Vd/Id.
Secondly, you may need a driver for the segments. If the segment outputs outputs of the circuit cant supply a current of Is to the segments, you’ll need a BJT/MOSFET driver for them. Note that a simple driver will invert the signal, so use a second BJT/MOSFET in front of each segment driver.
MOSFETs may be simpler than BJT transistors, especially for the segment drivers, because instead of calculating base resistors, you can likely use 10K resistors as pull-ups or pull-downs on the drain as needed.
demnikgr
Joined Nov 9, 2019
6
dear djfantasi,
I not sure I can follow you... the specs of the big Displays are in the next photo.. I 'm sending and the specs of the kits displays SA39-11EWA..
dl324
Joined Mar 30, 2015
18,476
What is the voltage drop on the segments?
It just occurred to me that the kit uses common anode displays. The displays you want to use are common cathode. That will require additional circuitry to do the required inversion.
demnikgr
Joined Nov 9, 2019
6
everything is common anode..
eetech00
Joined Jun 8, 2013
4,731
Welcome to AAC!
Judging from the TS statement that the LED's lit with 12v, the specs must reflect a single LED in a 5-LED segment.
However, TS also stated a "2.2k" limiting resistor which seems way too high. Should be more like 100 ohms for a 5 LED-series segment.
eT
djsfantasi
Joined Apr 11, 2010
9,237
eT
You have made some important observations. I didn’t see it in the spec, but Knowing the current draw of a segment is critical to know. Secondly, the voltage drop across a segment is just as critical b.
