Driving a MOSFET Full wave bridge rectifier
wayneh
Joined Sep 9, 2010
17,155
Nope.
Just have the simulation.
I'll add a caveat about that in the writeup. :oops:
One reason I never built one is I realized that the switching timing – the absolute requirement of avoiding shoot-through, but also the issue of gate ringing – was not something I could fix if it didn't work out of the box. So I wimped out.
#12
Joined Nov 30, 2010
18,223
There is a lot of demand for DC supplies below 20 volts. I wouldn't be surprised if this became available as a single chip like a 4 diode bridge rectifier. I hope your piggy bank gets full.
28,207
Well, any addition to my piggy would be fine, but that's unlikely from this circuit. :rolleyes:
I came up with the design for hobbyists who might want to roll their own using a common IC.
There already is a single custom chip (the LT4320) that does this (albeit with external MOSFETs), and is better because it uses all N-MOSFETs.
I posted a simulation of that chip here (post#33), near the bottom of the page.
(Still haven't figured out how they readily generate a gate voltage higher than the peak sine voltage). :confused:
28,207
Bootstrap capacitor.
That's the obvious answer. :)
But where's the large bootstrap capacitors needed to drive the large MOSFET gate capacitance?
I don't think they can squeeze two of those inside the IC package. :confused:
Edit: Found a description of the circuit here.
It has a charge-pump to generate the gate voltage and the on-chip capacitance is obviously sufficient to drive the gate capacitance.
k7elp60
Joined Nov 4, 2008
562
I posted a simulation of that chip here, near the bottom of the page.
(Still have figured out how they readily generate a gate voltage higher than the peak sine voltage). :confused:
Thanks for the information...of this post, I am really interested in mosfet rectifier cks.
Ned
28,207
My circuit doesn't have any shoot-through issues, since the N-MOSFETs change state at the zero crossing when the P-MOSFETs are off.
Gate ringing is generally not an issue with such a slow circuit.
ronv
Joined Nov 12, 2008
3,770
It is curious how they develop the gate voltage in the LT part. Very low drive current. I was thinking of a friend who builds high output alternators, but a big old fet wouldn't work.
srinath99
Joined Jun 30, 2017
6
I know this is an old thread and I'm guilty of necro-posting, but I wanted to add my circuit in case someone runs into this thread from a search for MOSFET Bridge Rectifiers and might want to consider this relatively simple approach.
My write up on the circuit is here.
Hi, continuing with the necro-posting trend...
I looked at your circuit and the OP's circuit and i have a thought... (I am just an electronics noob)
In the OP's circuit, if the bottom-mosfets of the H-bridge are P-type, couldn't a single Op-Amp comparator, drive the gates ?
ghulands
Joined Apr 1, 2016
Sorry to raise a dead thread again. I'm a novice when it comes to electronics so please be gentle. I'm looking at getting a 1.8kw wind turbine and wanted to try an active rectifier to eek out as much power as i can.
I've been looking at the Linear 3 phase demo board referenced in post #31 and can't work out why the board is rated for 25A. The MOSFETs are rated for 100A. Could someone explain why? If I were to replace them with 300A rated ones, would the rated amperage be 75A? Is there a linear relationship between the rated current of the FET and the rated current of the circuit?
Any help is greatly appreciated.
28,207
It depends upon the on-resistance of the MOSFET which determines its heating, and efficiency.
At the rated current the dissipation from the on-resistance may cause overheating of the MOSFET without a large heat-sink and/or reduce the efficiency by a significant amount.
So you want a MOSFET with a low enough on-resistance so that's not a problem. Likely, such a MOSFET will be operated well below its maximum current.
There is a relationship between the MOSFET's practical operating current and its max rating, but it may not be linear.
srinath99
Joined Jun 30, 2017
6
I want to use the synchronous rectifier to charge a battery (most probably LiPo)
I understand that battery chargers need to balance cell voltages and prevent overcharging.
So
1) Is there a reference design for a balanced LiPo charger ? Is there a writeup that explains it better ?
2) Would it be possible to interface it with the 3 phase synchronous rectifier mentioned in the threads above without having another DC-DC conversion stage ?
3) How does Battery chemistry play a role in design of the charger (LiPo, versus Li-ion vs Ni-Cd... etc)
