Draftsight / Geomtry help
spinnaker
Joined Oct 29, 2009
7,830
If you started out with a single line traced from the circle's quadrant, and then offset it to the sides, that would explain why the resulting lines didn't intersect with the referenced circle.
Why? It intersected when I drew the first line. Is it because that line "tilts" as it is being copied around the circle?
spinnaker
Joined Oct 29, 2009
7,830
First run was a dismal failure
I think I had some CamBam settings messed up.
Second attempt was a lot better but I forgot the center circle!
spinnaker
Joined Oct 29, 2009
7,830
Third time is the charm. I went with thinner tines. I left put the outside edge because I will be using it in the hard drive case for now and the case will provide that edge of the compartment wall. I suspect that I will need to add a bit of foam to provide a good light seal between compartments.
cmartinez
Joined Jan 17, 2007
8,853
So there's no need for an outer boundary for those compartments then?
spinnaker
Joined Oct 29, 2009
7,830
Not really. The hard drive compartment provides that. I will need to make those tines a bit longer. Turns out a 3.5" hard drive isn't really 3.5". ;)
I will also need to cut a groove in the back of my "shield". There are some screws behind there that aren't allowing the shield to lie flat.
I think what I will do is to glue some surface mount LEDs right to the hard drive case. I tested it and it is non conductive. I was going to use a proto board and mount them to that along with the current limiting resistors but I don't know if I will have the space. I might mount the number disk on top of that center axle in which case I would have plenty of space.
I am not exactly sure what keeps the hard drive disks spinning. They really aren't physically mounted to anything. I guess centrifugal force provides enough friction to keep the disks spinning.
spinnaker
Joined Oct 29, 2009
7,830
Fourth time is the charm. Or maybe it is the fifth time. I made the inner circle a bit larger to get around the screws. Now the thing lies flat. I made the tines a bit larger. Now I need to make the number disk.
