There's free software out there that generates g-code out of an AutoCAD dxf export, I think.I have a copy of CamBam. I don't know if it is something I am doing wrong or if it is because the demo is expired but I can't get it to generate g-code.
If you started out with a single line traced from the circle's quadrant, and then offset it to the sides, that would explain why the resulting lines didn't intersect with the referenced circle.
No, it's because the line steps away from the circle when it's offset to the sides.Why? It intersected when I drew the first line. Is it because that line "tilts" as it is being copied around the circle?
So there's no need for an outer boundary for those compartments then?Third time is the charm. I went with thinner tines. I left put the outside edge because I will be using it in the hard drive case for now and the case will provide that edge of the compartment wall. I suspect that I will need to add a bit of foam to provide a good light seal between compartments.
You need to get yourself a set of jeweler's needle files. They're perfect for finishing this kind of job.Fourth time is the charm. Or maybe it is the fifth time. I made the inner circle a bit larger to get around the screws. Now the thing lies flat. I made the tines a bit larger. Now I need to make the number disk.
Have a set. I plan to finish it off then paint, But that piece is going to be hidden behind the disk anyway.You need to get yourself a set of jeweler's needle files. They're perfect for finishing this kind of job.
| Thread starter | Similar threads | Forum | Replies | Date |
| T | Help me please | Homework Help | 3 | |
Need Help Identifying an Unknown IC / Datasheet | Datasheets, Manuals & Parts Identification | 1 | |
Measuring a section of a circle in AutoCAD / Draftsight? | Off-Topic | 15 | |
Draftsight / Autocad place lines equidistant? | Off-Topic | 26 | |
| T | Drawing using Draftsight | General Electronics Chat | 2 |
