You just use a command called "array", which works in both rectangular and polar mode .... in your case, it's polar modeHow did you do this in Autocad? Maybe I can translate to Drafrsight.
What thickness MDF are you planning to use?
Almost. Except that outside circle should go all the way around but I guess a half circle will do since it is only serving as a barrier for the LEDs.
I see you don't need my help...
Yes, but the trick is to draw the divisions first. Hang on a minute, and I'll show you the progression of how it's done.Do you just draw one "compartment" then use that array feature?
Scroll down to "pattern"
http://tutorial45.com/draftsight-basics-completed/
I use this feature in Autodesk Inventor and it is very handy.
I didn't determine anything, other than 10 divisions... if you watch closely, what I did was first determine the space between divisions (step #4), and then I generated a 10-element polar array (step #5). Then I just trimmed the inner and outer circles using the line pairs generated by the previous array command. AutoCAD does all that for you.How did you determining the length and arc of the arced edge of the compartments?
But you have to understand that I used arbitrary values for the width of the divisions, and for the diameter of the inner circle and the separation between the outer and inner circle. That's why I'd rather you gave me specific values to work on.
AFAIK still you have to pay. All the "free" downloads I run across where pirate copies of some kind of limited in time tests.Is there a free version of Coral Draw? Wonder if it is easier to use than this Draftsight.
The tool for that is called "offset". I just drew an initial straight line from the circle's center (as you've already guessed), and then I offseted it to both sides equidistantly.How did you make the initial "spacer"? I see you made one center line then added 2 more equidistant. I assume there is a tool for that? What should I look for?
| Thread starter | Similar threads | Forum | Replies | Date |
| A | Help me mosfet linear mode | General Electronics Chat | 70 | |
HELP: Creating high frequency triangle waves using comparators | Homework Help | 5 | |
Measuring a section of a circle in AutoCAD / Draftsight? | Off-Topic | 15 | |
Draftsight / Autocad place lines equidistant? | Off-Topic | 26 | |
| T | Drawing using Draftsight | General Electronics Chat | 2 |
