Draftsight / Geomtry help
spinnaker
Joined Oct 29, 2009
7,830
What thickness MDF are you planning to use?
I have some 1/4" on hand. That should do I think. It needs to be thick enough to be above the height of LEDs. With some of those super bright surface mount LEDs. That should do. I was thinking of using some of those strip LEDs too.
spinnaker
Joined Oct 29, 2009
7,830
You just use a command called "array", which works in both rectangular and polar mode .... in your case, it's polar mode
I wish I knew these drawing applications as well as a few of you. I will need to see if I can find a tutorial on "array" I think Draftsight has that feature.
cmartinez
Joined Jan 17, 2007
8,862
How did you determining the length and arc of the arced edge of the compartments?
I didn't determine anything, other than 10 divisions... if you watch closely, what I did was first determine the space between divisions (step #4), and then I generated a 10-element polar array (step #5). Then I just trimmed the inner and outer circles using the line pairs generated by the previous array command. AutoCAD does all that for you.
cmartinez
Joined Jan 17, 2007
8,862
But you have to understand that I used arbitrary values for the width of the divisions, and for the diameter of the inner circle and the separation between the outer and inner circle. That's why I'd rather you gave me specific values to work on.
spinnaker
Joined Oct 29, 2009
7,830
Light goes on! Ah so you just drew the divisions then copied / patterned/ arrayed those? Genius! And I guess you first drew the line from the center to get the first line perfectly centereted?
spinnaker
Joined Oct 29, 2009
7,830
Let me figure that out and get back to you.
spinnaker
Joined Oct 29, 2009
7,830
How did you make the initial "spacer"? I see you made one center line then added 2 more equidistant. I assume there is a tool for that? What should I look for?
atferrari
Joined Jan 6, 2004
5,029
Is there a free version of Coral Draw? Wonder if it is easier to use than this Draftsight.
AFAIK still you have to pay. All the "free" downloads I run across where pirate copies of some kind of limited in time tests.
Learning curve is steep. If you go that way, learnt how it works by understanding what you can do with every different element (of groups) you select. At least in the past they had very short tutorials that covered many many possibilities.
The CLONE function would be ideal for what you want to do. Whatever change you apply to the original, all clones will experiment the same change.
cmartinez
Joined Jan 17, 2007
8,862
The tool for that is called "offset". I just drew an initial straight line from the circle's center (as you've already guessed), and then I offseted it to both sides equidistantly.
