I just put in a Megalarm 1300 system in my 67 Camaro. The one thing that's got me stumped is unlocking and turning alarm off, the door locks won't go up. When locking and turning alarm the actuators will close the door locks properly.
There's continuity from the white wire at the alarm central module through to the actuators module where the white wire hooks into the purple wire. Brown goes to brown on the door actuator module brown wire and the white goes to the purple on door actuator module. The brown works as the door locks shut upon activating alarm but white not working as not popping up door locks when disabling alarm. One other thing is that the actuators do work in popping up manually....if I pull up on either door lock the other door lock pops up in sync, which is good news but just leaving the problem of popping up upon disabling alarm. Below is the schematic for the system.
How can I test by hooking up something to the purple wire at the door lock control module? The schematics say the white and brown wires at the control modules to be 300 mA. Is there some way to flash the white to purple wire to see if it makes the actuators pop up the door locks?
