Does i*cos = sin?
WBahn
Joined Mar 31, 2012
33,021
It's just as I said originally -- what you are seeing is a special case of "it works this time by coincidence".
You are mixing time-domain and frequency-domain components.
If your time-domain input signal is Vo·sin(wt), then this is
V_0 sin \left( \omega t \right) \; = \; Im \left\{ V_0 e^{j \omega t} \right\}
Now work with the complex signal and take the Imaginary component at the end and consider what happens if you multiply this by H = A + jB
V_0 e^{j \omega t} \cdot H \\
V_0 e^{j \omega t} \cdot \left( A \; + \; jB \right) \\
V_0 \left( cos \left( \omega t \right) \; + \; j sin \left( \omega t \right) \right) \cdot \left( A \; + \; jB \right) \\
V_0 \left[ \left( A cos \left( \omega t \right) \; - \; B sin \left( \omega t \right) \right) \; + \; j \left( A sin \left( \omega t \right) \; + \; B cos \left( \omega t \right) \right) \right] \\
V_0 \left( A cos \left( \omega t \right) \; - \; B sin \left( \omega t \right) \right) \; + \; j V_0 \left( A sin \left( \omega t \right) \; + \; B cos \left( \omega t \right) \right)
What are we left with when we take the imaginary part at the end to go back to the time domain?
So you can see that what you think you are observing is merely an artifact of the math in this problem.
I can't tell if your final step is correct because I don't know if you are going to use sin() or cos() for your final result.
