Does this circuit make sense?
kenzo42
Joined Feb 26, 2014
48
Newb question - this is a pool light that is controlled by a relay on a RP hat. The creator made this illustration. I am wondering if the black wire intersection (indicated by the red arrow) is correct? Shouldnt it be "not connected"? He's a very competent person, so I am questioning myself. Thank you.
WBahn
Joined Mar 31, 2012
33,348
It should not be connected.
Notice that the connection "dot" is only above the horizontal wire. This is probably meant to be the old style arc that "jumps over" the vertical wire. But because the wires are so thick, the arc needs to have a larger radius to make that clear.
kenzo42
Joined Feb 26, 2014
48
That makes sense.
28,600
NO!! That should not be connected. THAT is a poor drawing in post #1, while the revision shown in post#4 is correct, and much more useful.
The terminal connection shown in post #1 is traditional in the trade, but the sequence for this application makes no difference. ( The "traditon in the trade" I mention is conecting the power source to the common relay terminal, in case there is a reason to also require power to the opposite relay terminal. )
Most folks are not aware of that tradition, which actually makes some sense in some instances. I saw it in southern Lousiana back in 1967. Oil rig eletricians.
schmitt trigger
Joined Jul 12, 2010
2,292
MrChips post is a perfect example of how a simple drawing modification, is the difference between a functional installation and a potentially dangerous one.
AnalogKid
Joined Aug 1, 2013
12,298
The erroneous connection dot notwithstanding, I prefer the connections in #1 over those in #4. The mains hot (Line) lead should go to the relay COM terminal, and NO terminal should go to the switched load. This way, when the relay is "off" and the NO-COM connection is supposed to be open, there is not mains voltage at the NO terminal.
ak
35,299
I had no real intentions to interchange NO and COM.
I drew it this way otherwise I would have had to draw a "jump over" as WBahn correctly identified.
WBahn
Joined Mar 31, 2012
33,348
ak
On the other hand, when the relay is "off", there WILL be mains voltage at the NC terminal -- a terminal that is unused and just sitting there inviting something to touch it. With the mains going to NO, there will never be mains voltage on the unused terminal.
As with most things, pros and cons.
AnalogKid
Joined Aug 1, 2013
12,298
I knew someone would point out that . . .
True, but that terminal is clearly flagged as *Normally* (relay *not* activated / rest state) *Closed* (possibly connected to something electrically), and electronical-type-persons know what that means. It is the one you have to be careful with when things are "off". OTOH, the Normally Open terminal should be nominally less dangerous (your application may vary).
ak
