Does i*cos = sin?
jaydnul
Joined Apr 2, 2015
175
In circuit analysis, everything seems to work out when you set i*cos = sin. But thats not a legitimate equation, so why does that work? Is there a proof that this is a real equation?
jaydnul
Joined Apr 2, 2015
175
why would it be needed for resistors? sin across resistor gives I = sin/R. So V/I = R
Note: it should be i*sin = cos, i wrote it backwards in the title
jaydnul
Joined Apr 2, 2015
175
lol what? im saying in circuit analysis, you input a sin(wt) signal. If a phase shift happens that gives you a cos(wt) term, replace it with jsin(wt) and continue doing the algebra. resistors do not create any phase shifts so it doesnt even apply
jaydnul
Joined Apr 2, 2015
175
another example:
i have a transfer function given by the complex number (A+jB). I multiply my input sin(wt) and i get Asin(wt)+jBsin(wt). Using the equality above, it becomes Asin(wt) + Bcos(wt), which is just standard form of any sinusoid with a magnitude of sqrt(A^2 + B^2). No need to convert into an exponential with eulers formula, then take the "real" part of that exponential.
WBahn
Joined Mar 31, 2012
32,704
Clearly i*sin(Φ) is NOT the same as cos(Φ).
To show that they are not the same, all that is needed is a single counter example. So set Φ = 0. The cosine of zero is 1, while the sine of zero is zero, and multiplying that by i does not make it equal to 1.
In general, if Φ is real, then both sin(Φ) and cos(Φ) are real. For any value of Φ that yields a non-zero value for sin(Φ), you then have a pure imaginary number when you multiply it by i and that is not going to be equal to the real number that you have cor cos(Φ).
It' hard to tell what you mean when you say "everything works" in circuit analysis.
But here's something to consider.
The use of complex numbers in circuit analysis can be formulated several ways. The two most common are to note that:
sin(Φ) = Im(e^(jΦ))
cos(Φ) = Re(e^(jΦ))
Pick one or the other. Let's pick the first.
Now, when you analyze a circuit (let's start with one that only has DC sources or AC signals/sources operating at a single frequency) you can write all of the sinusoidal signals in terms of the Im(e^(jΦ)). In doing so, you discover that you can "factor out" the step of taking the imaginary part of the equations that result and do that at the very end. So you "transform" the equations into this complex number realm at the beginning, so all the math with straight complex numbers, and then transform it back into the original realm by keeping only the imaginary coefficient of the result.
jaydnul
Joined Apr 2, 2015
175
ya i understand how to do complex circuit analysis, but i just realized that it always works out the same if you replace cos with jsin. I am just wondering why. Perhaps it isnt an equation, but more of a bridge in and out of complex analysis? cos <==>jsin
WBahn
Joined Mar 31, 2012
32,704
another example:
You can't transform part of the system and not transform other parts. The (A+jB) had to have come from transforming something from the real world into the complex frequency world. You need to transform your input signal accordingly. The product of a complex frequency domain factor and a time domain factor is meaningless.
jaydnul
Joined Apr 2, 2015
175
I guess im not asking why something giving me the wrong anwer, I am asking why it gives me the CORRECT answer.
Why i simply replace all cos terms with isin, do the algebra, then replace all the isin terms back with cos and somehow magically always get the correct answer.
WBahn
Joined Mar 31, 2012
32,704
Just because 2*2 = 2+2 does not mean that multiplication and addition are interchangeable.
We can't see what you are doing right or wrong or figure out under what conditions what you are doing might happen to result in a correct answer unless you provide a clear example, worked step by step, so that we can see exactly what you are doing and where you are doing it.
Papabravo
Joined Feb 24, 2006
22,058
Because you have looser requirements for mathematical equality than the rest of us.
jaydnul
Joined Apr 2, 2015
175
As far as i can tell it serves just as much purpose as complex exponentials. Please prove me wrong
Whats more abstract, taking the “real” part of some complex exponential, or assuming multiplication by j is a 90 degree shift to sin.
WBahn
Joined Mar 31, 2012
32,704
More importantly, this serves no purpose in real life and is just an academic masturbation
Rather hard to justify that claim given all of the design techniques for all kinds of systems, particularly in the realm of signal processing and communication systems, that are based on it.
Ian0
Joined Aug 7, 2020
13,097
Euler's equation: cosx+jsinx=e^(jx)
also cosx-jsinx=e^(-jx)
so if cosx=jsinx then e^(-jx) must always be zero?
