DC voltage controle for dynamo
Free sandwiches
Joined Apr 25, 2017
6
The dynamo gives out 6-140volts I want to charge a 12v battery bank using a water wheel. I'm used to solar power, the controllers only go up to 50v.
Bernard
Joined Aug 7, 2008
5,784
Is the dynamo connected to the water wheel in an operating system ?
Is the 6- 140 V DC ?
What is power rating of dynamo ?
What is Ahr. rating of the battery bank ?
Have you ever tried varying the field current to see the effect on output V ?
The control might be = or similar to an older 12 automotive alternator regulator.
I know nothing about water powered dynamos.
Kermit2
Joined Feb 5, 2010
4,162
Put a few light bulbs in parallel on the genny. Several 60W incandescent bulbs would do nicely. Then what is the highest voltage you get?
I suspect it needs a load bank for dumping excess power when charging finished or other loads go off.
Free sandwiches
Joined Apr 25, 2017
6
The dynamo will be connected directly to the water wheel in an operating system.
The power rating of the dynamo is 1000watts see link below
http://www.ebay.co.uk/itm/112360400708?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
The battery bank will be 240Aph
I have not tried anything yet still waiting delivery.
The company selling suggest
a normal charge regulator from 30A
but these seem to have a top limit of 50v
I'm thinking that I probably will not reach this voltage
LesJones
Joined Jan 8, 2017
4,511
I do not believe that your 2 inch diameter water wheel will turn this motor with it's 240:1 step up (When used as a generator.) gearbox. The information in the advert contradicts itself. The claim that the gearbox steps up POWER is wrong. A gearbox will always output slightly less power than the input power.
Les.
Alec_t
Joined Sep 17, 2013
15,114
Even if the wheel is 2 feet diameter I share your doubts, Les. Maybe if the wheel is positiond at the foot of Niagara Falls it would work :).
Kermit2
Joined Feb 5, 2010
4,162
At 1600 gallons per minute with a 10 foot head there is 4.0 water horsepower.
It can work with sufficient flow rates, but 2 inches dia. Is a LONG way from 1600 GPM.
Bernard
Joined Aug 7, 2008
5,784
From "Producing Your Own Power", Net horsepower available at turbine shaft = ( cubic ft./ sec. X gross head in ft.) / 8.8 . You would need about 2 HP or better for 1 kW DC output.
A 2 ft. dia. wheel seems fine depending on type & head.
Free sandwiches
Joined Apr 25, 2017
6
Thankyou for all your replies
it is an under driven water wheel and I am building the prototype. I will post my results.
Alec_t
Joined Sep 17, 2013
15,114
So, it's a bit like a paddle-steamer operating back-to-front :).
What is the maximum speed of the catamaran?
What will the dimensions of the paddles themselves be?
Kermit2
Joined Feb 5, 2010
4,162
Under cut water wheels are only 30-40 percent efficient. So whatever power calculation used for available water energy will be reduced by the efficiency factor of the water wheel type you choose. Spiral vanes on a flat surface wheel with center intake and peripheral outflow can be over 60 percent efficient.
Alec_t
Joined Sep 17, 2013
15,114
At 209 wheel rpm, with 100:1 gearing (the gearing spec is confusing and says "Ratio 240:180:120/1") the generator shaft would be spinning at an unrealistic and over-spec 20,900 rpm! Rated rpm is 6000.
Bernard
Joined Aug 7, 2008
5,784
Sounds like it might work, now to original question -how to control output. I'm guessing that wheel can be raised & lowered, if so, gross control might be by depth of immersion, fine control with a buck converter, or charge controller. Output V can be monitored & cause disconnect or raise signal if V approaches 50 V?
Might look at -www. greenenergyhydrocat.
