DC power supply
35,320
From what I can glean, this is a motor home space heater that uses diesel fuel and operates from 12VDC.
TS wants to connect this to 240VAC mains using a 12VDC power supply hence no drain on battery.
Audioguru again
Joined Oct 21, 2019
6,826
What about the problems of having the fire, the carbon monoxide and the stink inside the motor home?
The furnace in my home does not have those problems.
Since mains electricity is available, why not use a safe electric heater?
Ian0
Joined Aug 7, 2020
13,317
Probably because the amount of current is limited at some sites. But don't all motorhomes have propane/butane cylinders?
Ya’akov
Joined Jan 27, 2019
10,370
I was thinking the same. Going to stay away from amazon and ebay. Aiming for one of the main electrical uk suppliers
Amazon and eBay are not the problem, badly designed and built supplies are.
You should look at a Meanwell supply, and it doesn't matter where you buy it so long as it is a real one. On eBay, you could potentially save money buying a used one.
Another route is the surplus market, brands like Delta and Power One are top quality industrial grade supplies that can sometimes be a bargain. One thing that makes it a little hard for you is the 12V requirement. 12V supplies are very desirable making them generally more expensive on the surplus market.
Also does any one know what the best casing I can put this power supply in?
The general answer is a NEMA enclosure that has enough room to work inside. If this will be mounted outdoors you will need one with a suitable rating for outdoors and damp locations. You also need to consider heat.
You can use a simple vents and cooling fan approach if the enclosure will be in a protected location, but if it has to be placed outdoors, the best route is probably a metal enclosure with the supply mounted directly to one face of the enclosure in intimate contact to have the enclosure act as a heat sink.
Ian0
Joined Aug 7, 2020
13,317
An ordinary laminated or toroidal transformer plus rectifier and smoothing capacitor will do the job. If the unit is designed to run off a 12V battery, it won't be too fussy about voltage, ripple etc.
Ya’akov
Joined Jan 27, 2019
10,370
I suspect it works like the kerosene heaters used by construction workers in cold climates. Simply atomizes the fuel, mixes it with air, and burns it, blowing the heated air into the room. Seems a bit dangerous CO wise.
They use a heat exchanger (which could be as simple as the heater housing) so the combustion products are never in the airstream.
Ya’akov
Joined Jan 27, 2019
10,370
There is a control board that manages starting and stopping the diesel burner and fan, as well as monitoring the housing temperature for safety. The electronics don't look very complicated but the might be more sensitive to supply parameters than you'd expect.
Audioguru again
Joined Oct 21, 2019
6,826
A car has a long exhaust pipe leading the CO away from people.
My home has a tall chimney.
The diesel heaters produce deadly CO without an exhaust pipe or chimney.
Ian0
Joined Aug 7, 2020
13,317
In @MrChips 's picture in post #37, isn't the heat exchanger the device that looks like a silencer, and the device that looks like a coffee-machine pump the atomiser?
Tonyr1084
Joined Sep 24, 2015
9,744
Yeah, mine too. However, I know a Marine friend who owns a very old home with a "Pre-WWII" furnace. The natural gas flame is directly in the air stream. No venting whatsoever. She's financially struggling so she can't afford a new furnace, even though someone's going to say 'She can't NOT afford it.' And I agree. However, without the funds she's not going to get there. A few of our friends have pooled some money together to help but it's no where near enough. In her home there's also Asbestos to be managed properly.
Thought about GoFundMe but I've learned that what's donated comes with an income tax bill that can be a big surprise at tax time. I've reached out to the local news channel that from time to time they like to give away to someone in the community who is deserving. She's definitely deserving. She's helped MANY Vets get their paperwork done with the DAV (Disabled American Vets). Both working for DAV and on her own time. She's been a valuable resource for many Vets with PTSD and other psychological conditions and yet we can't find suitable help for her.
Sorry for the tirade. Back on topic. There have been a lot of good points made regarding exhaust gas management. I believe it's been said before but if not - we need a very clear picture of what we're trying to accomplish. Till then you're going to find comments all over the board.
Audioguru again
Joined Oct 21, 2019
6,826
Money to pay for a new furnace and a new air conditioner?
The Canadian Government helped me pay for a high efficiency furnace and air conditioner. They also payed entirely for a new high efficiency refrigerator, a Smart thermostat and additional insulation in the attic.
My government also pays for all my medications, doctors and occasional operations.
Tonyr1084
Joined Sep 24, 2015
9,744
@Audioguru again Thanks. Don't know why I didn't think of that before.
Anyone else who may have a comment or suggestion regarding my OFF TOPIC comment, please PM me. I don't want to hijack this thread for my purposes. Thank you.
Jon Chandler
Joined Jun 12, 2008
1,660
Never have I seen so many people spewing off without a clue of what they're talking about. A five second search for "8kw diesel heater" shows exactly what the TS is talking about.
If you don't understand what the question is about, you have a few options:
● Say nothing and don't prove your ignorance
● Ask for more information
● Spend literally a few seconds searching on the terms in the question to see if it clarifies anything.
Three forum pages of rubbish might have been saved, and the TS concluding this site is worthless.
35,320
Sorry, I have to disagree with your analysis of the situation.
I asked for clarification. TS has been rather scant on information. If TS wants to conclude this site is worthless then that is his prerogative.
For starters, TS should have told us the make and model of the unit.
We still don't know what is the role of the 12VDC power supply.
Jon Chandler
Joined Jun 12, 2008
1,660
I guess you're too (insert your choice of adjectives here – you might not appreciate mine) to click the link I posted. Diesel heaters are not a great mystery. The willfull ignorance here is amazing at times.
35,320
Granted, I am ignorant as to what is a diesel heater. I had to look it up. I know what is diesel fuel. I know what is a heater. "Diesel heater" is not in my lexicon.
Every TS (thread starter) should have the courtesy to state up front the make and model of any unit that needs our attention if they desire our assistance. Time and again we have to ask for make and model. A link to the device/specifications/schematic would be even nicer so that we don't have to look it up.
Audioguru again
Joined Oct 21, 2019
6,826
The first link for 8kW diesel heater was an ad from Amazon who also do not know how it works. The second link is from Vevor who says, "It Runs Quietly" and "The Exhaust Pipe Must Be Outdoors".
28,626
Clearly chandler does not know that there are also fuel heaters for diesel engines, as well as glow plug heaters that are part of some diesel engines. Each one quite different from a diesel-burning heater, which, by the way, I would never use.
So before spewing venom about those who are conversant with other systems that are more correctly named "diesel heaters", chandler should consider that others may know things that chandler has never been aware existed. Not only do many others have a vastly broader amount of experience, some of us also avoid amazon as much as we can. And some of us avoid following links that others post.
