- Joined Jul 18, 2013
- 30,658
One reason could be is that the Semi Cond. Tab bolted to the heat sink may originally be insulated from the H.S. and you inadvertently shorted the tab to the heatsink proper?
Not really. Maybe it's better to modify the box - PITA that it will be - and avoid these issues entirely. So there's little chance the the LED indicator lamp somehow caused the board failure?Another possibility is that static electricity, generated by you or by the grinding process, killed the MOSFET on the heatsink. Did you take anti-static precautions when handling the controller?
I apologize but I have no idea what those things are or what they look like. However, the board failed (single-speed output) instantly upon power-on. No time to even warm up the heatsinks.If you are enclosing the controller in a tight-fitting project box then the heatsink won't be very effective. Perhaps the controller died from being cooked.
Does the motor/controller have a back-emf protection diode or snubber fitted?
The motor seems fine. It still varies its speed using a resistance-type controller.Wired to the power input side of the controller I would not have expected it to blow the controller, only the LED itself maybe?
If it states good to 28vdc then it most likely has a built in resistor, going higher would need an additional series resistor.
Have you attempted to confirm the motor itself is OK?
A quick google will give lots of info on those.I have no idea what those things are
