Hi, I need help. I'm already at a loss. I need a DC boost convertor from a 6V solar panel. Constant 12V output. Does anyone have a working schematic?
I plan to make a small model of the use of a solar power plant. It will be a small house where on each side of the roof there will be a 1*6V solar panel composed of these cells in series. And a few panels folded like this will be around the house. I will connect all these panels in parallel. I would need the output current as large as possible, ideally 1.5A to 2A, but if it is 1A, that will also be enough.Buy a second solar panel and put the two in series.
. . .but seriously - how big a solar panel? How much output current?
It would be much more sensible (and it takes less cable) to connect them in series to get the voltage you need.I plan to make a small model of the use of a solar power plant. It will be a small house where on each side of the roof there will be a 1*6V solar panel composed of these cells in series. And a few panels folded like this will be around the house. I will connect all these panels in parallel. I would need the output current as large as possible, ideally 1.5A to 2A, but if it is 1A, that will also be enough.
This forum is supposed to be conducted in English. Is there some reason you feel the need to translate and repost my writings?Našel jsem zajímavé schéma. Bude to fungovat? https://www.google.com/amp/s/www.instructables.com/Step-up-Booster/?amp_page=true
I never knew I could speak Czech. Perhaps I ought to take a trip to a Prague and try out my new-found skills, and perhaps bring back a few bottles of proper Budweiser.Ian0 said:
Bylo by mnohem rozumnější (a vyžaduje to méně kabelu) zapojit je do série, abyste získali potřebné napětí.
byl by to také mnohem přesnější model, protože tak jsou zapojeny v normální instalaci.
Sorry, I'm writing in English, but Google probably translates it into Czech again.I never knew I could speak Czech. Perhaps I ought to take a trip to a Prague and try out my new-found skills, and perhaps bring back a few bottles of proper Budweiser.
