datasheet for Philips VCTCXO
Berthen
Joined Feb 11, 2024
4
Hi I am searching for the datasheet of this hi accuracy oscillator.
TCVCXO or VcTCXO.
I have a few of those 10MHz , 1.5ppm oscillators from an older project , but cannot find the datasheet anymore. They where is an philips databook for Quarz devices as I recal, but I lost that book when I moved.
I think the philips part no started with 9922.515 but I am not sure that is from an old partlist
Hoped to find that info on google etc but no success
The info that I have is in attached pictures showing the bottom and top side and a part of the schematic that I had saved in a file.
I hope someone could help me?
34,817
Have you applied power and tested it?
Pin-1 GND is on the upper right corner.
Pin-3 +5VDC is the lower left corner.
Use an oscilloscope to determine where is pin-2, 10MHz output signal.
Berthen
Joined Feb 11, 2024
4
Hi Yes I know they work , the schematic is one of my own from quite some time ago.
I needthe specsheet bcause I got some Questions about a system That we designed in the past and try to answer those.
The accuracy ( I think 1.5 ppm) over time, temperatur and also the environment temps
Faizaishtiaq
Joined Mar 27, 2024
1
TCVCXO or VcTCXO.
View attachment 314970View attachment 314971View attachment 314972
Berthen
Joined Feb 11, 2024
4
Hi Thanks a lot, but tha is not the part:(
I checked the PCB and the pin marked 1 at the case is GND.The pin numbering at the device is pretty odd.
I stil have some boards here with the circuit.
From that I am able to assign the proper signals to the pins
From pin 1 on the photograph counter clockwise
