MisterBill2
- Joined Jan 23, 2018
- 28,220
A patch panel will be simple for anybody to wire without a schematic drawing. I used to do it building tube type amplifiers. But one certainly need the pin-out of each tube.
So how are you isolating the MOSFET's grounds between amps?I do not plan on sharing any grounds from the speakers or amps
I think you are correct, I plan on buying the following.A patch panel will be simple for anybody to wire without a schematic drawing. I used to do it building tube type amplifiers. But one certainly need the pin-out of each tube.
Understood.I’m not using the MOSFETs to switch signal grounds, only floating speaker outputs.
And how is that?it's not necessary for how my switching is designed.
The isolation between amplifiers is achieved because each amplifier's speaker outputs (L+ L− R+ R−) are routed through their own dedicated MOSFETs. In theory, there’s no electrical connection between the drains of different amps. So, every amp gets its own set of 4 MOSFETs (one per speaker line), and those MOSFETs are only active when selected via the cam switch.Understood.
But the MOSFETs need two DC connections, source and drain, to be controlled.
How are the drain connections isolated between amplifiers?
And how is that?
This is not piling on; it is a serious question: Do you really expect to get *circuit* advice on a site with *circuits* in the title, in a forum called "Analog & Mixed-Signal Design", without showing us your *circuit*?
Paraphrasing Rear Admiral Joshua Painter,
"Engineers don't take a dump, son, without a schematic."
Then how are they are isolated, as all amp outputs will be connected to that shared bus, and the sources are connected to the amps?all the MOSFET sources go to a shared bus
I might be totally off on this but my logic is that amps are isolated because each one's speaker output runs through its own set of MOSFETs. There will be 96 total MOSFETs. When a MOSFET is off, it should act like an open switch—no connection, no current. I assume that even though all the sources go to a shared speaker line, only the selected amp’s MOSFETs are turned on, so only one amp is ever connected at a time. Am I off on this? Is there a better way to accomplish this?Then how are they are isolated, as all amp outputs will be connected to that shared bus, and the sources are connected to the amps?
To the speakers, yes, but the sources are all connected together which means one output of all the amps are connected together, which is likely a recipe for disaster.only the selected amp’s MOSFETs are turned on, so only one amp is ever connected at a time.
Since you would need to totally isolate the connections to each MOSFET, it's likely easier to use a double-pole mechanical relay for each amp.Is there a better way to accomplish this?
Could you post the circuit here?A video of the Nixie tubes in operation.
https://drive.google.com/file/d/1-ZZSxoUzWGR22MpWbU1f9uX-ZocAprYI/view
As I am doing the schematic, you are correct, I do NOT have enough MOSFETs to isolate the grounds. I would need 8 MOSFETS per amp. That gets a little too much......To the speakers, yes, but the sources are all connected together which means one output of all the amps are connected together, which is likely a recipe for disaster.
Alternately a solid-state relay with a bipolar MOSFET DC output (not AC which use SCRs) would work (example).
Would the CPC1020N 30V, 1.2ADC Single-Pole Normally Open Relay be rated a little too low? Is 1.2A DC too low?To the speakers, yes, but the sources are all connected together which means one output of all the amps are connected together, which is likely a recipe for disaster.
Are you not able to see the video?Could you post the circuit here?
Google is aking for email address.
To be clear, there are at least two. First, there is no GND at the power supply, so *none* of the digital and analog signals have a reference potential / return current path / whatever. Second, you show two FET sources connected together (good) but not connected to anything else (bad). Third, there is a high voltage supply that needs to be referenced to the low voltage control circuits.Here is my drawing, now I see the aforementioned ground issue
