ronsimpson
- Joined Oct 7, 2019
- 4,903
Are you measuring 3-phase power line?The three-shunt topology is 3 shunt resistors for 3 currents,
Please find the asc file attached, i used the same file given by @ronsimpson only changed the capacitance value.hi V123.
Please post your latest LTSpice asc file.
E
I am measuring the 3 phase motor currents.Are you measuring 3-phase power line?
The recommendation is to use 300KHz, not sure how the value arrived? Can you please tell how you chose 10KHz in future i can understand for other circuits.Then you should filter at 10kHz.
I would suggest using a differential amplifier configuration and the Kelvin connection, then you can avoid any attenuation, and any error caused by resistance between the ground side of the shunt and real ground.
If you mean 3-phase MAINS currents, then you would be better off with current transformers.I am measuring the 3 phase motor currents.
The recommendation from whom? Must be someone completely ignorant of sampling theory and the Nyquist criterion,The recommendation is to use 300KHz, not sure how the value arrived? Can you please tell how you chose 10KHz in future i can understand for other circuits.
Hello,Please find the asc file attached, i used the same file given by @ronsimpson only changed the capacitance value.
