I'd just change that to "if this is for an application where you require this to current to be logged over an extended time" or something like that.There are a number of ways depending on voltage and the current range you want to measure. If this is for an industrial application I would use something like this.
Ron
OK.I'd just change that to "if this is for an application where you require this to current to be logged over an extended time" or something like that.
