This wig-wag throttle pot has 5 wires - three of which are connected to the POT (hall sensor) as usual, but the other two wires (red and black) I'm not sure of.
I've run 4.5v through the pot (leaving the red and black wires out for now) and returned a center voltage (@ 1.4V... lower than I would expect) - but there is no response from the signal when the lever is rotated. There is voltage present at the black wire @ 1.4V and at the red wire about 0.7V when the pot is supplied with 4.5V.
I could find no wiring diagram to adequately explain the situation. If someone could enlighten me on the RED and BLACK wires.... or way to test. As this is from a mobility scooter, these wires may be used to moderate the throttle (speed) with another pot (the rabbit/turtle knob).
