Hello partners
I come to you to help me determine what resistance values or what other components I need to be able to design a crowbar circuit that protects my sensor against overvoltages.
My intention is to take care of my sensor for voltages above 40V. So I started to design this crowbar from scratch. Well what did I do?
First look at the components page of my nearby store to see if I will have the components for your construction.
So I chose the 15-volt zener diode, and a 90-volt resistor that I sized using the current from the zenner, this current was obtained by dividing the power by the voltage and thus I obtained that the value is 0.0666. On the other hand, the current that the sensor will consume is around 29.4mA, but I have not yet put the microcontroller, the rtc, a datalogger and an Xbee. Therefore it should consume around 343mW.
But hey anyway, I just want my circuit to protect me from surges greater than 40 volts.
When I do this test, the simulation doesn't work and it's frustrating, I don't know what I'm doing wrong.
It is assumed that the gate voltage of the SRC thyristor is at 6 Volts therefore in the resistance of 90 6 volts have to fall, when the current is 66.66 mA. This causes the SCR to activate and conduct shorting and preventing the sensor from burning out.
